Question about Nokia 6300 Cellular Phone
Memory card problem
I have nokia 6300 and when i chang themes it shows lack of memory
althoug the memory card is empty.....what should i do????and the same problem for sms......what do i do????
How to download themes for my nokia 6300 phone...
You have to download themes that are specific to the screen resolution of your phone.
S40 devices uses a different kind of theme in the format of .nth
S60 devices however use themes in the format of .sis
For Nokia 6300, you need a theme with .nth extension
You may visit mobile9.com or zedge.no to download themes on your pc.
You can transfer using the usb data cable provided when you bought the phone, just connect using PC Suite Mode then install the theme.
Alternatively, you can transfer the themes on your memory card (through a memory card reader) then apply the themes directly using your phone.
Mar 12, 2011 | Nokia 6300 Cellular Phone
My nokia6300 doent work propery.when i want change theme it say 'theme is corrupted'and i put 1GB memmory card,it switched off itself.pliiz help me.
I have exactly the same phone as yours. =)
In my honest opinion I think changing themes from time to time is what did it to your phone. Try to stick to a single theme thay you like and if you want to change the background, just do it using wallpapers.
Switching from one theme to another often leaves sort of a chached info which goes directly to your phone memory. It dos not matter how big your card is, eventually the phones memory will run out and it will trigger a whole lot of new problems.
Oct 08, 2010 | Nokia 6300 Cell Phone
Hi all, my nokia 6300 is switching "off" and getting "on" automatically. Please tell me what to do!! Please tell me the format code for nokia 6300. I'm waiting for your reply
If you have a memory card remove it and restart your phone.If the phone works OK now, then format your memory card after backing up the data.Always take care to keep your memory card half empty.
*#7370# is the format code for your phone.
You can format your phone in this way too.
1.Turn off your phone
2.Press and hold *, 3 and green button at the same time.
3.Holding these buttons turn on your phone.
Release these buttons only when the screen shows formatting procedures.
May 09, 2010 | Nokia 6300 Cellular Phone
I have no memory card.
Yes, but you are limited to the phone memory.
Aug 26, 2009 | Nokia 6300 Cellular Phone
Changing the theme in my nokia 6300 china phone
you have download 6300theme,first you scan the vires,next you trans for memory card to apply the phone
Aug 17, 2009 | Nokia 6300 Cellular Phone
Theme on my Nokia 6300 resets every time I switch it off
move th etheme from memory card to your phone memory now apply it. it will be fine
Jul 04, 2009 | Nokia 6300 Cellular Phone
6300 corrupted themes
tema nggak bisa di ganti
Apr 01, 2009 | Nokia 6300 Cellular Phone
I can't open downloade theme in my phone nokia 6300
Turn the phone off remove the battery and memory card and then place them back after 1 min and switch it on.
Feb 06, 2009 | Nokia 6300 Cellular Phone
Nokia 6300 Problem with GPRS setting
nokia 6300 phone memory capacity is 7mb, if ur images, tones, vedios n recived files r there in phone memory plz move to memory card. 1 more thing if u have applied high quality theme then change it simple 1. it may solve ur problem.
Aug 01, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
29 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
