Also do you hear any clicking when you depress the trigger?
You should. If nottry to jump the trigger wires inside themachine right where it goes out to the "gun"wires? worksnow? problemis in the gun cord somewhere.
Still not working? CHeck the contactor. SOmetimes a boxelder bug will get inthem and prevent them from working, or the contacts fry themselves.
Make sure selector switch is not in between settings, this is where the wire feed voltage comes from.
Well you shorting the wire inthe machine will do no good since the contact tip gives the wire the charge. i would check to make sure the ground is connected at the machine. if that is ok u may have to open up the gun and look to make sure the wires are connected. the trigger is made out of plastic so if u abuse your welder you could have broke it
