Question about IBM Computers & Internet
Comstar USB Drive disconnect and reconnects Plugged into usb port on Xp service pack 2
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Posted on Sep 08, 2009
Hp simplesave not recognized xp
Unfortunately XP is no longer supported. You could try reinstalling the OS from your CD.
Jul 31, 2017 | HEWLETT-PACKARD Hewlett Packard HP...
We have a Comstar 640gb external Hard Drive. All tests say drive is healthy. Running Windows XP. Drive was working yesterday when hooked up to our old PC. Now on new PC Windows will see the HD and we can...
Can I ask a question about this Comstar 640gb external Hard Drive? What kind of power adapter for this external Hard
Drive? How many volts? I lost my power adapter for this hard drive while moving.
Steven
Feb 04, 2010 | Fantom Drives Titanium II (TFD160U2) 160...
My pc told me to un-plug my printer from a standard usb port into a high speed usb port, but where are the ports? It gave me the USB hub & ports in a pop-up which is now gone.
Dear,
Have you installed winxp service pack 2. only after service pack 2, xp support usb 2. instllall the latest service pack and try the same
Oct 16, 2009 | Dell Dimension 3100 PC Desktop
How to install usb
After you install Microsoft Windows XP Service Pack 2 on a computer that is running Microsoft Windows XP, the universal serial bus (USB) drivers do not appear to update. CAUSE After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers... loadTOCNode(1, 'cause'); After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers appear with the earlier version numbers, even though the files have been updated. uparrow.gifBack to the top RESOLUTION To resolve this problem, install Windows XP SP2, and then update the drivers for... loadTOCNode(1, 'resolution'); To resolve this problem, install Windows XP SP2, and then update the drivers for the USB devices that are connected to your computer. To update these drivers, follow these steps:
  1. Click Start, click Run, type devmgmt.msc, and then click OK.
  2. Double-click the type of device that you want to update.
  3. Double-click the specific device that you want to update.
  4. Click the Driver tab, and then click Update Driver.
  5. Follow the instructions in the Hardware Update Wizard.
  6. Repeat steps 2 through 5 for each USB device.
Note You can also install Windows XP SP2, and then disconnect and reconnect the USB devices that are connected to your computer. By doing this, you start the Plug and Play utility. The Plug and Play utility updates the version numbers for the drivers.
May 08, 2009 | Microsoft Windows XP Home Edition
Activate usb port for my computer
you need to install update then windows XP to service pack 2...
The USB drivers are there in service pack 2...
Mar 21, 2009 | E-Machines emachines (emachinees) CD-ROM...
Front usb ports not working
not likely,
what pc model???
try serach for usb software. your might be too old. "usb2.0"
Oct 10, 2008 | Computers & Internet
HP Pavilion DV8000 Laptop USB problem
did you try reloading the BIOS drivers?
Apr 03, 2008 | HP Pavilion dv8000z Notebook
I am not able to use my san disk 2 gb on my office system on xp
Just a few questions about your system and we should be able to resolve your problem fairly quickly. Firstly is your xp a service pack 2 installation, secondly is your usb ports usb 2.0, and finally does other usb devices work properly when plugged into the same physical usb port on your pc?
Scan disk drives have the driver and application software on a partition built onto the drive thats not accessible for write access, meaning you cant format that partition. Other systems see that partition just fine, but it seems your system is having trouble doing so. Theres a few reasons for this trouble. If you can provide me with the detail i need about your system im shure we can resolve your issue promptly.
Nov 29, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
USB DVD ROM no detected
You need XP service pack 2 or later installed on your notebook. Does your notebook detect other USB drvices, if not your USB port on the PC is gone. If the USB prt is working and you have XP service pack 2 installed then you probably got a bum DVD drive so return it and get another.
Jul 14, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
130 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
