Question about Garden
Starter cord will not rewind after being replaced. The string will rewind in the housing before it is attached to the motor but not after being attached. How do you pre wind the springs?
  • 138 Answers
What I do is the following:
Remove the old rope ( what is left of it)
Wind the starter rope pulley about 8 or 9 complete revolutions after I am confident that the spring has engaged the starter pulley
Hold the pulley in place ( align the rope hole in the pulley with hole in the starter housing
Insert the rope and tie a knot, pull the rope back tight against the pulley
Pull the rope all the way out and hold slight tension on the rope and release the tension on the pulley but still holding the starter housing
Starter spring should pull rope into housing... good luck
Posted on Sep 09, 2009
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
How do I replace a pull cord for pm 605 mcculloch chainsaw?
First remove the pull starter housing.
The next part is tricky. You'll have to release and unwind the spring that rewinds the pull starter cord. Remember how you do this because after replacing the cord, you'll have to rewind the cord and spring before inserting it back in the housing.
re-attach the pull cord housing to the chain saw.
Hope this helps.
Oct 19, 2014 | McCulloch Pro Mac 605 610 645 650 655...
Cub Cadet has broken pull cord
pull off cap first from engine look inside it pull the rest of the cord out to the end then grab the not onthe pully while holding it pull the rope out after that wind pully all thee way up shuve a new cord throug houseing pully then slowly let rewind up until it stops cut the rope 6 inchs in front of cap hole restall cap to motor slip your starter rope threw grip that you pull pullthe cord attached to handle out two feet hold onto rope cut handle loose slip[ and tie handle again to the houseing rope dont let go of the rope after that let it rewind back up done
Sep 04, 2013 | Garden
Starter cord has jammed
You will have to remove the starter rewind mechanism and rewind the cord around the pulley, then pre- load a certain amount of tension on the rewind spring.
Apr 17, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
I have this Toro trimmer/edger.Can't pull the starter cord
you must take apart the cord recoil and rewind the pull string,inspect string make sure its the same thickness through out if not replace it, not too hard i believe you can do it.
Apr 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
Petrol Lawn Mower starter cord and spring problem
remove the shroud Ithe cover over the flywheel) and remove the old rope. now rewind the spring in the opposite direction of the string hole until the spring is tight. Then clamp it down so i won't unwind and reinstall a new rope (the same size) into the notch in the pully and tye a knot. then release the clamp and let the cord wind onto the pully(make sure the cord gose through the hole in the shroud. then replace the handle and reinstall the shroud back onto the engine..Good Luck
Apr 04, 2010 | Garden
The pull cord is stuck, can't be pulled to start
This solution applies to the Sears model 358.797200, which also appears to the FL1500LE marketed under the Craftsman name, and may apply to other, similar, blowers. Go to the searspartsdirect.com site and enter the Sears model number. This blower may be prone to develop binding in the pull cord rewind spring compartment. (The binding may easily be misdiagnosed as a seized up engine.) The binding can be fixed by adding washers to increase the spacing. Open the rewind starter page on the sears site for an exploded view. I found that by placing 2 washers on each of the 5 screws (no. 7 on the diagram) which attach impeller housing (12) to the motor, I increased the spacing enough so the pull cord operated and retracted normally. The washers must go between the impeller housing and the motor. To complete the repair, you need to add a washer between the spacing flywheel (14) and the impeller(15) to keep the impeller from binding against the housing. The gasoline tank screws won't line up as well with the holes, but will fit. Install all 3 screws for the at first loosely, then tighten them down.
Oct 25, 2009 | Garden
Rob poulan leaf blower how to rewind pull string
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled. HTH
Lou
Sep 05, 2009 | Poulan Garden
Poulan Wild Thing 18 Inch replace starter spring?
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
Lou
Oct 09, 2008 | Poulan 1630 16" Chain Saw
Garden Logo
748 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
