Question about Kenwood DV-605 Multi-disc DVD Player
Dv-605 kenwood only says hello when power is urned on
  • genob45 Sep 12, 2008
    when i turn it on it just says hello and does nothing more
  • Fizban257 Nov 15, 2008
    The system was sitting with the power off, turned it on this morning and all we can get is the hello message.
I have a similar issue with my DV-605 as well. When the unit power on, I can hear the motor trying to start, but the DVD does not spin. Being the adventurous type, I opened the case and turned the DVD drive motor a few revolutions by hand and then the dvd played. I think I need a new DVD drive motor. You may as well....
Posted on Nov 25, 2008
Kenwood CD/DVD player moder DV-605 tray is jammed, how can I manually resease it
you have to play the disc in another player or you can change the type of the disc.. the player is just not compatible with your disc.
Dec 08, 2012 | managemylife.com
Only shows loading on face of player
either some how the remote has become unsinked or the reciever is bad in it
May 22, 2012 | Kenwood DV-605 Multi-disc DVD Player
Burnt DVDs will not play
It is possible that you're player will not play burned DVD's. If you have the manual...or even on the front panel of the player, it should say that it can play DVD-/+R, DVD-/+RW, or even DIVX.
Also, have you tried to play it in your PC to make sure it can play?
Hope this helps
Dec 22, 2010 | Kenwood DV-605 Multi-disc DVD Player
Disc tray does not come out, display say hello
There is a flex cable that attaches the tray assy to the main pcb ,make sure that has not pulled out, also see if tray tries to move at all as it may need the mechism realigned and the open/close switches cleaned.Also the is a gear that turns the tray that has broken teeth on,check that gear ,as tray must turn before unit will intalize
Apr 16, 2010 | Kenwood DV-605 Multi-disc DVD Player
It is displaying a loading but there is no disc and it will not move. I have reset it like it says in the manual but no luck.
yes bad electronics took mine apart put it back together it worked fine till i turned it off . you have to tap or hit the front above the buttons and sometimes move stuff around then it will work wires boards but be sure its not plugged in
Sep 07, 2009 | Kenwood DV-605 Multi-disc DVD Player
Re: Kenwood DV 605 CD Player... Power On: Reads "Loading." All 5 CD lights are lit up but the CD changer does not turn. CD #1 appears on screen with two green lights appearing.
ace71cf.jpg We repaired this problem by taking the advice of another member of FixYa! The component had recently been packed to be shipped. After unpacking the unit when we powered up the read out only displayed "LOADING" and the CD changer door would not open. We removed the exterior cover and gently moved the CD changer one position. When it locked back into position we powered up and the unit works fine now. FixYa sure help me save perhaps a $100. or more by not sending it to the manufacturer or another shop. And it was working within minutes so we could enjoy using it right away. Thanks guys I very much will recommend this sevice to others... this was the 2nd problem we fixed that day by logging onto FixYa!!!
Z-Dawg
Dec 06, 2008 | Kenwood DV-605 Multi-disc DVD Player
Tray will not open on my dv-605
Solution: Unplug power from wall. (Don't just turn off!) Next: Remove exterior case. Now gently turn the CD changer clockwise one position. Power up and try again.
I had this same problem after unit appeared to have froze up when unpacked from a shipping box. The CD changer had got off track and by gently moving the CD changer 1 position it fixed the problem. Works fine now.
Best of luck,
Z-Dawg
Apr 30, 2008 | Kenwood DV-605 Multi-disc DVD Player
Disk error with Kenwood DV-605 multi-disc DVD player
Try the following
when the error is on the screen, press the number 1 key on the remote, this should take you to the fist chapter of your DVD no matter which region it is
Miguel
Jan 03, 2008 | Kenwood DV-605 Multi-disc DVD Player
Kenwood DV-605 Multi-disc DVD Player Logo
248 people viewed this question
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
