Question about Garden
Homelite xL2 will not start spark OK Gas seems OK as far as carb
    Sergeant:
  • 302 Answers
To begin, turn both of the carb jets out 1 1/2 turns from bottom. spray some starting fluid in the cylinder after removing the spark plug and then install a brand new plug. If it fires then try it again with the choke on. If it still won't start then you have carb problems. Also make sure that the air filter screen is clean with no holes in it. Hope this helps
Posted on Sep 08, 2009
Have spark dos'nt start ? homelite 26cc
Since you have spark then you need gas or air. I made some videos on giving my Homelite a tune up and carb rebuild. Got all the parts form Home Depot and the carb rebuild kit from Amazon. Didn't cost much for all that.
Aug 18, 2014 | Homelite Garden
I have a old homelite that won't start new plug fresh gas no spark
Most of the time on older engines, the carb needs to be rebuilt or replaced. Dont panic rebuilding is cheap an easy. The ports get clogged up sitting an varnish up. Try to clean out all orifices with small pieces of wire from steel or brass brush. Use carb cleaner to clean replace all gaskets an parts with kit. Dont forget to check fuel hose in tank they go bad often an should be replaced when carb work is done. Fresh gas an it should work
Mar 11, 2014 | Homelite Garden
Zama carb pulls gas when not running
throw the carb out and buy a new one. there is an internal issue that can not be fixed
Mar 20, 2013 | Homelite Garden
Need to know what carb screw adjustment need to be set at weedeater starts for about 4-7 sec then shuts down put new hoses on checked gas filter and cap checked out ok. i pump the ball about 10 times...
If there is a choke adjustment you should set that at full until the trimmer warms up, don't touch the gas. Then repull start at half choke, don't touch the gas either at this time. Then start at no choke, and then set your idle on the carberator with the adjustment screw. Also don't push the primer bulb so many time you will cause the spark plug to get flooded and drown out the spark, which is exactly what is happening.
Sep 06, 2010 | Homelite Mighty Lite Lawn Trimmer
My 16" Homelite chainesaw will not start. I have fresh fuel, and good spark.
Remove the spark plug and try spraying starter fluid or carb cleaner into the cylinder. If it starts and then dies you probably have a carb problem and will probably have to clean it. You can try spraying carb cleaner in it and see if it helps. If it has been sitting, if could be due to the fuel. Gas has ethanol that attracts water and causes corrosion and clogging problems in the carb. You can use a fuel stabilizer to treat your gas and avoid this problem. Hope this helps.
Feb 28, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Old gas, will not start. homelite "timberman 45"
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 30, 2009 | Homelite Garden
Will not start. few months old. maybe bad gas
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
1) spark plug
Chain Saws:
Remove Carburetor
Nov 15, 2009 | Homelite Consumer Products Backpack...
Need to repair Hpmelite leaf blower UT08930A. Where can I download repair manual Some spark, but may be weak? Carburetor does not seem to get gas to cylender when starting rope is pulled ? Plug shows no...
I think Home Depot carried Homelite these days. Im 99% cerain that there is a web site for Homelite.
I think you have a carb problem ... address that part first.
Oct 12, 2009 | Garden
Trimmer fires up but then stops , I pump the bulb and it starts again but then stops
Ok... 1. Make sure your Air Cleaner is clean 2. Empty out any old gas in the system from last season. from the tank, carb, and fuel lines. 3. Make sure that the gas filter in the tank is clean and free from blockage. 4. Clean out the carb jets with spray carb cleaner. 5.Pull spark plug and clean wih carb spray as well. 6.. Reassemble n fill with fresh gas/ or gas/oil mix if 2 cycle. let me know how it goes... k
Jun 10, 2009 | Homelite Garden
Garden Logo
223 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
