Need to Dismantle A Philips x56
Taken out all obvious screws but still can not remove the top from the bottom.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 129 Answers
Generally manufactures gives the user manual to understand the machine structure. Please check if you have one.
Else try to remove the screw which is on the keyboard and under stickers which is on the back.
Please investigate the screws or hole under the sticker with fingers. If it is there you can continue with removal.
Recommended: Do not try to open laptop at home untill unless not having proper knowledge.
Posted on Sep 08, 2009
Remove cd/dvd drive on philips freevents laptop
use a pin on the hole in front of CDROM to open the CD ROM
May 14, 2012 | Philips Brand 12.1 WXGA Glossy Laptop...
Acer 5610 DC jack problem - need to dismantle laptop
The solider tends to loseen up on the power connection.Make sure all screws are removed some are under the covers on bottom of laptop slightly pry the top up where ever it seems to be holding look for a screw underneath where its holding.if all screws are out it should come off fairly easy.
Oct 05, 2009 | Acer Aspire 5610-4648 Notebook
Need to replace keyboard on Philips freevents x56
There is one screw holding the keyboard in from the bottom - remove this, unclip the 4 clips across the top with a bank-card etc. and you're away. Remove the ribbon, Replace, and reverse for re-assembly.
Jun 30, 2009 | Computers & Internet
Unsure how to access drier to put on new drive belt
Here is my own solution...
Disconnect from mains (of course) remove top (2 screws at back near top) Unplug electric connectors (on back panel, top RHS). Make sure note what goes where! Lie unit down on front remove screws (2) holding the drum spindle cover (centre of back) and remove cover pop off the circlip holding drum spindle, and washer unscrew back panel - hex headed screws round outside of back Remove screws at bottom of back panel which screw into the plastic vent housing (3 I think) Lift whole back off. (there's a plastic lip at bottom - need to pull away from this a bit) The drum spindle will be unsupported now, so don't move unit Full access now to drum and motor beneath Get and put on new belt reassemble.
Actually, having got into unit, found could not get belt from local spares shop (it had closed down), so bought new drier!
Dec 15, 2008 | Zanussi TD4212W Electric Dryer
Ps3 dismantle instructions
1. To remove drive you only need to remove small plastic door with fine flat screw driver under small **** towards the front of console then undo blue screw and slide drive towards front of console and pull straight out. Be careful not to press on any of the drive's surfaces especially where the label is as head or platter will be damaged!
2. To dismantle the rest of the console, remove sticker on left side of console, remove rubber plug/ foot, undo tamper proof screw with correcy T15 star driver, and slide false plastic cover towards you. Then you have several philips head screws all marked with arrows to undo after which the top can be removed straight up. When removing or disturbing the optical drive be careful not to damage the heat transfer pad under the drive as the electronics of the drive will then overheat. The rest should be easy!
Nov 29, 2008 | Sony Playstation 3 (PS3) Console
Kenmore C880 6587590 burner switch replacement.
I just replaced the switch just yesterday.First remove the glass panel by pushing back the 2 black clips at the top end,then remove 2 silver screws at the top and 3 at the bottom also remove 2 black screws behind side panels on the top. Now push side panels slightly up and forward and it fill fall forward and now replace the switch.
Feb 21, 2008 | Kitchen Ranges
Twinhead 12D Laptop
Are you sure you have all the screws out, there is a small plastic disc on the bottom of the laptop underneath the card slot, this needs to be removed to access a screw (obviously take out plastic blank in slot first).
And there is not much reason to dismantle LCD either.
What is it you are trying to do.
Dec 04, 2007 | Twinhead SlimNote N12PI Notebook PC
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
