Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
Refigerant in oil recovery bottle
During vaccume cycle and tank refill the refrigerent gets thrown into the oil recovery bottle
    President:
  • 180 Answers
You have to change/rebuild oil drain solenoid & check oil drain check valve.
Posted on Sep 09, 2009
Need to change coolant recovery tank can a anyone do it
Yes you can do it yourself
Degas Bottle Removal
  1. Drain radiator (8005) until engine coolant is out of degas bottle. Disconnect radiator overflow hose (8075) and engine coolant vent hose at degas bottle.
  1. Remove power steering oil reservoir retaining screws and position power steering oil reservoir (3A697) out of the way.
  1. Remove degas bottle return hose and clamp. Remove degas bottle retainers and remove degas bottle.
Installation
  1. Position degas bottle in vehicle and install retaining screw and nut. Tighten retaining bolt and nut to 9-12 Nm (80-106 lb-in).
  1. Connect degas bottle hose and clamp to degas bottle.
  1. Position power steering oil reservoir onto degas bottle and install retaining screws securely.
  1. Connect radiator overflow hose and engine coolant vent hose to degas bottle.
  1. Fill and bleed engine cooling system as described. Check for coolant leaks and proper engine coolant level after engine reaches normal operating temperature.
    Item Part Number Description 1 8100 Radiator Cap 2 - Nut (1 Req'd) 3 - Bolt and Retainer (1 Req'd) 4 - Nut (1 Req'd) 5 - Bolt (1 Req'd) 6 - Coolant Recovery Hose 7 - Coolant Return Hose 8 - Coolant Recovery Hose 9 8A808 Degas Bottle A - Tighten to 9-12 Nm (80-106 Lb-In)
Hope this helps.
Zeppelinx12
Mar 08, 2011 | 1999 Ford Taurus
My wife put a small bottle of 2 cycle oil directly in the gas tank of my Weedeater edger and then added gasoline. Bless her heart she tried to help me out. Emptied the tank and refilled it correctly but...
Take the air filter off and make sure it is not soaked with oil. Leave if off. Get some carburetor/choke cleaner and have someone spray it into the carburetor throat while you are pulling the starter. You may have to open the choke to do this. You may also need to pull the spark plug and clean it if it is oil fouled. Hopefully, no real damage has been down and the machine will eventually start.
Nov 28, 2010 | Poulan Garden
We need to put oil in our scooter, but have no idea if it's a 2-cycle, or 4-cycle engine... We own a 2004 Yamaha Scooter Attack... We bought 2-cycle motor oil, but it gives us ratio on the back of it,...
CHECK THE OIL DESCRIPTION ON THE BOTTLE, IF IT READS SUITIBLE FOR PREMIX AND AUTOLUBE,THEN THE OIL WOULD BE FINE FOR EITHER USE, PREMIX SIMPLY MEANS YOU MIX IT WITH THE PETROL AND THE ENGINE IS LUBRICATED AS THE FUEL ENTERS THE CYLINDER IN AN ATOMISED STATE. AUTO LUBE YOU WOULD PUT THE OIL INTO A CONTAINER IE A STORAGE BOTTLE BUILT INTO THE MACHINE, LIKE THE LITTLE HOLE NEXT TO THE GAS TANK YOU DESRIBED AND THE OIL IS FED BY A PUMP AS THE ENGINE RUNS TO LUBRICATE THE ENGINE , I CAN ASSUME IF YOU HAVE A STORAGE BOTTLE NEXT TO YOUR GAS TANK WHICH HAS SOME DESCRIPTION OF ENGINE OIL THEN YOUR MACHINE IS A 2 CYCLE AND NOT A 4 CYCLE IMPORTANT DO NOT ALOW THIS OIL TO EMPTY AS YOU WILL HAVE TO BLEED THE SYSTEM TO REMOVE AIR AND ALLOW THE OIL THROUGH.
PE. UK
Oct 30, 2010 | Yamaha G5 Motorcycles
Goodman CLJ36-1A with bad Copeland Compressor CR30K6-PFV. Any suggestions where to get a replacement compressor?
Not a DIY project. You'll need refrigerant recovery equipment, vacuum pump, manometer, refrigerant scall, refrigerant disposal bottles, high pressure nitrogen tanks and regulators, acetelyn tanks with regulators and torch tips not to mention EPA license. Call a reputable service company. In South Central PA, fair price range is $1,500 - 2,000. If the unit is more than 10 years ole, replace the condenser (if they can get one for your refrigerant) for about $1000 more.
Jul 18, 2010 | Goodman CLJ36AR42 Air Conditioner
How do you transfer new refrigerant to tank
Connect fill hose ( Black hose with 2/1'' quick connector located at near the tank strip) to source tank (New R134a refrigeration tank) & make up side down. switch on the machine power switch. Press main menu key then keep pressing up or down arrow key till appear "Tank Refil" on the display screen. with "Tank refill" on screen press YES key. the message will change to ''Checking source tank" for few second then start filling refrigerant to ISV tank. press NO key to exit when you want to stop filling.
Hope this will help you, Good lucl & vote for my solution!
Jul 13, 2010 | Robinair Cool Tech 34700Z Recovery,...
Water in the fuel tank wrangler 97
Sorry the isn't a drain plug on the fuel tank. Try this go to walmart or home depot and buy a kerosene can hand pump plastic cost $3 to $6 remove the hose coming from refill to tank cut off a piece of old water hose approx.5ft insert into tank from opening insert hard plastic portion of hand pump into water hose have something large enough to contain the fuel and start pumping open valve on pump to release pressure may have to pump several times to get it flowing good do not try to **** on hose pump will work once all gone reconnect hose and refill fuel with one bottle of Lucas fuel treatment and one bottle of Marvel Mistery Oil drive it all out refill fuel again with one last bottle of Lucas fuel treatment. wutxtye0rjd9d9ekmodqt1eoxkvn9hr9qjz1l3dabggyud7sdgr36czsrfxqenadhnijx9nfayi+sz1sug0aaaaasuvork5cyii=
Apr 22, 2009 | 1995 Jeep Wrangler
Refigerator leaked oil after moving and storage
no if there was oil leaking out then that means the refrigerant has leaked all out. you will have to have it repaired by a service tech.
Feb 22, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Oil failure on Ryobi PNC 4545 chainsaw
It sounds like you have a contaminated oil source. I'd buy a new bottle, clean the tank again, and see if things improve.
Jan 18, 2009 | Garden
My engine is making a light/medium ticking noise. it increases with acceleration. i have 95 neon with a 2.0L SOHC. what is causing this noise?
check your oil........ it sounds like a lifter in the top of the engine. if you let it go to far you might take the chance of having a rod thrown through your engine.
Aug 03, 2008 | Plymouth Neon Cars & Trucks
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
410 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
