Question about AEG 24 in. Favorit 80820 Free-standing Dishwasher
AEG Favorit 80820 dishwasher tablet door opens as soon as switched on and door closed. When you put the power on and select a wash and then close the door the small grey dishwasher tablet inside the door can be heard to open as soon as the door is closed. Normally this door remains closed until asked to opened automatically by the dishwasher at the correct point in the selected wash program.
SOURCE: AEG Favorit 50730 Sensorlogic Dishwasher:
get a new dishwasher
Posted on Nov 06, 2008
SOURCE: AEG Favorit 40650 dishwasher is
Remove the controller from the top of the door. Extract the main PCB from the plastic case. You will probably see a burn mark on the inside of the case adjacent to the relay on the back of the PCB. Examine the back of the PCB for burn marks around the relay pins. Resolder the relay and any damaged track.
Posted on Nov 11, 2008
BIKER T
  • 909 Answers
SOURCE: AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
Posted on Sep 16, 2009
joe_lishman
  • 192 Answers
SOURCE: AEG Favorit 50730 Dishwasher
The dishwasers have heat (inductive) elements in line with the top sprayer hose and is about +/- 15 cm long and has an electrical push on clip at the side of the device.
Posted on Jan 19, 2010
joe_lishman
  • 192 Answers
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
Aeg 60870 dishwasher water not getting in
The most common cause of a fault "i10" is closed valve on the water supply line. So this failure indicates a problem with filling of water.
Possible error causes:
Closed water tap, Inlet valve faulty, inlet hose bent, softener system clogged, pressure switch or pressure switch hose obstructed or leaking, wiring from pressure switch to printed circuit board (PCB), wiring from inlet valve to PCB and finally PCB.
Dado
Oct 04, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Why C3 code on dishwasher favorit 5081
Problem with inlet water.
Could be: water tap closed, pressure switch....etc
Dado
Jun 19, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Favorit 40010 vi dishwasher the machine door opens during the wash except on eco 50 wash
Strange it remains closed on one stage? Usually a door that opens by itself is due to misalignment, and then gain water will leak onto the floor. If someone banged into the side of the door and moved the washer a slight bit, the locking tab under the work counter may not be in a positive position. If the tab is bent slightly up, the door may barely make contact and lock when in operation. A simple movement of the washer could pop the door open. Other than that, any electrical dysfunction would require a professional servicemans attention.
Mar 17, 2014 | AEG 23 in. Favorit 44070Vi Built-in...
AEG Favorit 6040 Dishwasher has continuous tone (from Pump?) even when switched off at the power button. It cannot be set to any programme.It overflowed some froth when put on a recent cleaning 'phantom...
This sounds like the anti flood system has triggered. This does put the washer on a pump out mode and the outlet pump runs all the time. The trigger device is a polystireene slab in plastic bracket with miro switch at the bottom of the washer. Dry the bottom out and check for water leaks (hose clamp / hose) and this should solve the problem.
Nov 11, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Door latch in closed position
put two small screwdrivers in each side of the latch and lever upwards (best way) or otherwise take the door outer panel and fascia off so you can get at them
to stop it reoccuring, bend u catch on cabinet slightly downwards
Jul 20, 2008 | AEG 18 in. Favorit 54750Vi Slim-Line...
Detergent Dispenser does not open
I had this problem - the dispenser only opens if there are small items in the rack in front which don't come up to the same height.
Jan 08, 2008 | AEG 23 in. Favorit 86070Vi Built-In...
Integrated dishwasher door fitting
open the front door. On each side of the inside of the door are various long screws, unscrew these and the old door will fall off. discard the old door and follow the same steps in reverse to put the new door on. It took me 10 mins to do. Hope this helps
Apr 12, 2007 | AEG 23 in. Favorit 50750Vi Built-in...
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
AEG 24 in. Favorit 80820 Free-standing Dishwasher Logo
108 people viewed this question
Top AEG Dishwashers Experts
paul
paul
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
