Question about GE Spacemaker JVM1640SJ Microwave Oven
Been cursed with the 666's
I woke up this morning with a constant beeping in my kitchen. I walked in to find out that it was my microwave beeping 66:66 on it. I tried to reset thinking one of my kids was playing with the microwave and none of the keys would work. So i then unplugged it and plugged it back in. All of a sudden the 6's started beeping back onto the screen. I ended up unplugging the microwave all together and got my holy water. I thought i had been cursed and started blessing the whole kitchen. Later when i got home i plugged back in the microwave and after 2 minutes the 6's started beeping on the screen again. I then jumped online and was relieved to see that i wasn't the only chefmate microwave owner to have this problem. It seems that after about a year you will end up having the same curse! I was reading all the post and LMFAO!
  • GE Master
  • 9,098 Answers
You have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
Posted on Sep 12, 2009
The beeper will not shut off on my advantium 120 m/w
Is there a code "F3" in the display too?
That would mean the key panel (part number WB27X10467 key PCB assembly) is shorted.
The service manual is here if you or someone you know want to check it out and possibly do the work.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Jan 29, 2010 | GE Advantium SCA2001BSS Microwave Oven
My Panasonic microwave oven has started ''beeping'' the night during cold weather and also if the kitchen door is open sometimes. This morning the Micropower button is not working so am unable to use the...
Hi the touch mabrane panel will be faulty and need to be replaced. Best place to obtain one of these or a service engineer is from the manufacturer. www.panasonic.com
Hope this helps
Jan 07, 2010 | Microwave Ovens
Whirlpool Microwave Hood Combination MH3184XPS-0 (October 2004), for no reason at all, this morning keeps beeping and running the power setting down from 10 to 1, and just keeps doing it in rapid sequence....
Ours just started doing this exact same thing this past Friday - 12/11/09. What's going on? The cook power just starts beeping all by itself and going from 10 down to 1 over and over again. It may stop momentarily, but then starts again within a minute or so - it's constant until we unplug it. We plug it back in and within a few minutes it starts doing it again. What gives?
Dec 08, 2009 | Whirlpool MH3184XP Microwave Oven
Microwave beeping and F2 error code
hi,
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
thank you,
vijay (vote for me)
Sep 23, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Starts constant beeping with F3 on the screen
I thought I was helping my daughter out by clenaing her kitchen, well the inside of her microwave was pretty bad and very hard to clean so I was a spray to loosen up the crusted on food. In doing so it started beeping and flashing F3 and now we can't get it to do anything. How do we saolve this?
Jul 17, 2009 | GE Microwave Ovens
POSSESSED MICROWAVE!
wow.......... an exorcism may be in order.......Sadly your microwave circuitry is malfunctioning which is a costly repair. I would seriously consider trashing that possessed unit and purchasing a new one. the new ones are greener too, use quite a bit less electricity
Jul 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Outlet works but the microwave is dead, no power at all.
I had a similar problem with my Whirlpool microwave. I replaced a fuse (after reading posts in this forum) and it's working again.  I'm not sure how similar your model is, but in my case it was an in-line fuse in a wire leading down from the main fuse in the upper right corner behind the control panel.
Apr 04, 2009 | Whirlpool MH7140XF Microwave Oven
Chefmate microwave oven won't start, only flashes numbers.
Well I had the same problem. It made me start unplugging a microwave when it wasn't in use, which is always a plus.
When it does the whole 6666 thing, press 5 and then stop/reset. It usually allows me to input what I want after that.
Good luck people.
Jan 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My Microwave flickers and buzzes
This problem normaly happens when the door is not closed properly for a long time and flashing and buzzing starts to give user a indication for same. Allthough it is not risky as microwave oven has safty door switches wich does not allow oven to operate while door is open. Take care and close the door properly before you leave kitchen..
Aug 02, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
Starting by itself
Time for a service call. Should not turn on by itself at any cause. Circuit board is my guess. May be cheaper/easier to get new microwave. My first one lasted about 15 yrs--and the circuit board (touchpad) died. Bought new microwave oven.
Dec 12, 2005 | Emerson MW8775W Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
328 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
