Question about SansuiM1315 TV
Sansui Model: TVS2542A 27" TV
Sqeaking sound. When plugged unit doesn't do anything but squeak. No buttons work,what has happened? Help please
  • Sam036 Feb 07, 2008
    What are dry joints?
Check line output transformer, look for dry joints
Posted on Feb 07, 2008
  • kas1 Feb 08, 2008
    dry joint is a soldering joint that has become (a bad connection) to resove this just resolder the component. dry joints are often had to see, and can catch you out easily
We just put in heating coil works good but now its sqeaking
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 21, 2011 | Frigidaire Dryers
Delonghi Magnifica Rapid Capucinno Power button not working. Hi all, We have a delonghi coffee maker that stops working few weeks ago. The machine doesn't power up. When you plugin into the outlet...
It's quite likely your unit had a blown thermal fuse caused by a bad thermostat. Test them by disconnecting one end and a meter should show continuity if the part is good. The pro's test them in circuit while the unit is plugged in, power showing across the part means it is bad. REPLACE BOTH PARTS TOGETHER.
Jul 02, 2017 | DeLonghi Esclusivo Magnifica ESAM3300...
I am trying to get the aux outlets to work on the tv how do i do that?the universal remote i have is not putting the tv on that channel and i have the red white and yellow jacks installed in fron of the tv...
Try using the channel buttons on the front of the tv to go below channel 1. If this doesn't work you will need the original remote or you could try a different universal remote. You can use an RF modulator, available at walmart or radio shack, to feed the signal through the antenna jack on the back of the set.
I hope this will help you.
Bobya.
Mar 07, 2011 | Sansui DTV2700 27" TV
My truck is sqeaking around the belt? I have replaced the tenion pulley and the idler pulley but it is still sqeaking?
if the belt is dry replace it to for it will squeak as well.
also a glaze can be on all pulleys so wire brushing them all will clean the glaze off and eliminate the squeaks too
Jul 31, 2010 | 1992 Ford Ranger
Repais tv
Sounds like a shorted picture tube. Or it could be a blue drive problem. Hard to say. Thanks for using fixya.
Mar 03, 2010 | Sansui 27" TV
Jeep Cherokee - Sqeaking Undercarriage
If the "sqeak" is more pronoused while going over bumps, then it is most likely a bushing in the front end. Check your fuel tank straps also, they may be loose. Sounds like this are always a pain to locate. Make sure nothing is in the back cargo area. You can also take your foot and shake the exhaust, WHILE THE CAR IS COOLED OFF OF COURSE.
You can also push down on each corner of the vehicle in the front and stand on the rear bumper to try to simulate or isolate the noise. That's all I have for ya. Good luck.
Feb 02, 2010 | 1996 Jeep Cherokee Sport
Sqeaking when kneading oster 2 loaf bread machine - how to oil?
Take out the bread pan and go to a kneading cycle. See if it is squeaking. If yes, then it could be the belt squeaking on the pulley or the motor itself. If it does not squeak when the pan is out, then it's the bread pan paddle and sealed bearing. That sealed bearing is lubed and sealed. It can't be oiled. Hank
Jan 18, 2010 | Oster Kitchen Appliances - Others
Squeaking during right turn only on 02 grand cherokee
Try applying brakes slightly when squeak occurs, and see if noise goes away or changes.
Jul 01, 2009 | 1995 Jeep Grand Cherokee
SansuiM1315 TV Logo
218 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
