Question about Hoover F5872-900 SteamVac Wet/Dry Vacuum
I can't find replacement tool caddy with tools for a Hoover steam vac model F5872-900.
I can't find replacement tool caddy with tools for - retrieveimage.aspx?code=sm&model=36433167 http://www.hoover.com/parts/?category=carpetcleanertools The tools are available at this same site. Tool Caddy Keeps your Steam Vac tools organized. Model #: 36433167
Price:
$13.03
Quantity:
View Larger
retrieveimage.aspx?imageid=7991
Posted on Sep 16, 2009
Why will my hoover spin scrub steam vac upholstery attachment not suction?
With this model, check all hose connections and recovery tank lid. if you have good suction before you put on the tool it may be the tool that needs service. inspect the tube under the recovery tank for the round gasket and the filter inside the tank.
Aug 26, 2014 | Hoover SteamVac F5914-900 SpinScrub...
How do I switch from tools to flooe on my hoover steam vac ? it is green next to tools do I need to change iit to floors ro clean the carpet?
Hi Cherie! To switch from tools back to floor you only need to disassemble the hose from the cleaner. Be sure to close the circular hose port on the nozzle. Hope this helps!
Jun 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
How do I switch from tools to floor on my hoover steam vac ? it is green next to tools do I need to change iit to floors ro clean the carpet?
Hi! To switch from tools back to floor you only need to disassemble the hose from the cleaner. Be sure to close the circular hose port on the nozzle. Hope this helps!
Can't find info for hoover steam vac spin scrub model # F5905900 on Hoover website, doesn't show that model number at all...looking for mesh (kind of cone/cylinder shape) that goes in dirty water tank (I...
The cleanout tool is part # 43514001. The filter is # 90001398. Be sure to leave a 1/2 inch gap between the top of the filter and the bottom of the lid. If you need a manual, try model F5914-900 0r F5912-900 on Hoover.com
Mar 18, 2011 | Hoover SteamVac F5914-900 SpinScrub...
How do I clean the hoover steam vac floor cleaner machine
Nozzle Clean Out tool is NO LONGER AVAILABLE from Hoover. Hoover stopped making this part over 1 year ago, and it's not sold any more. What you'll need to do is remove the dirty solution thank, unscrew the one silver screw on the suction port of the clear window, then turn the machine upside down and remove the two silver screws on the bottom corners of the see thru window. This will then allow you to completely remove the see thru part to clean inside of it. Unfortunately with this model that's really the easiest way to do it now that the tool is no longer available.
Apr 18, 2010 | Hoover SteamVac F5914-900 SpinScrub...
The power button quit working
Please click here to see the part diagram for the Hoover Windtunnel Self Propelled model U6446-900
Greetings from GoVacuum,
For replacing the switch, you need to remove the 2 screws that are in the back of the vacuum where the handle connects to the vacuum bag housing, Part # 50 on the first page of the diagram. After the screws have been removed, you may simply slide out the handle from the rest of the vacuum cleaner. You can then at this point view the outside of the switch, however as you'll find you can't replace it from this side. You'll then need to go into the where the tool caddy is in the front top part of the vacuum cleaner. Remove the attachments from the tool caddy, and then you'll need to remove the screws that hold the tool casing in place. Remove screws pictured # 35 on page 1, and the tool caddy is item # 17.
Once the screws and the tool caddy are removed, you may then see the rest of the switch, and the leads that connect to it. The easiest way to remove the screw is to use a flat head screwdriver and pry the switch out from the back of the vacuum cleaner after removing the leads from the switch. The new switch that you'll need to purchase is Hoover part number 28161067 which can be found online here: Hoover Windtunnel Main On / Off Switch Part Number 28161067.
I hope that this helps you replace the faulty switch in yours (and your parents) vacuum cleaners. If you need to place an order for the switch, please give us a call at 1-866-468-2288.
Thank you,
Chris Jones
GoVacuum.com
Mar 18, 2010 | Hoover U6446-900 WindTunnel Bagged Upright...
How to use the tools on the hoover steam vac dual v
I am unable to give you 100% information, since you did not post your Model Number. Please use the following link to access the Instruction Manual for the model you have pictured:
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Feb 27, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac LS F5897-900
get a copy of the manual at this site
http://www.vacuums-cleaners-bags.com/
Aug 07, 2008 | Hoover F6055-900 SteamVac Maxextract LS...
Hoover Steam Vac Clean Surge
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=407245
Posted by just a brat on Feb 22, 2008
I can not seem to get the attachment for the upholstery cleaner to operate what am i doing wrong????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The attachment works on the suction from the Hoover Steam Vac and it’s either a straight suction tool or a revolving brush, check the front of the machine to see if the is a switch to turn on and odd, also before you attach the upholstery tool check the end of the hose for suction, it may be that your upholstery tool may be clogged or the brushes are not spinning and a part may be broken. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Feb 22, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F5872-900 SteamVac Wet/Dry Vacuum Logo
81 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
