Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Chainsaw pull cord wont tension up
Its a craftsman 18" 42cc chainsaw, part number shows 42cc:twc. I cant find part diagrams or anything on replacement parts to see if the reel that holds the spring broke or anything. I need to figure out whats wrong and how to fix. Thank u
    President:
  • 2,220 Answers
Its almost certainly made by Poulan.
This may help you find an IPL at Sears, they are available:
http://www.searspartsdirect.com/partsdirect/modelHelp.pd?modelNumberId=29
This lists all Poulans. It will be difficult to find your saw but it is here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
It sounds as though the starter spring is broken.
This thread explains how to reinstall the spring.
http://www.fixya.com/support/t1839024-broken_recoil_spring
The IPL for your saw shows all the parts and provides an idea of how they fit together. GL
Lou
Posted on Sep 08, 2009
Where can I get a new trigger for my craft an electric chain saw?
Are you sure it isn't a 'CRAFTSMAN' chain saw?
Google
make model spares
Craftsman Chainsaw Parts ' Great Selection ' Great Prices ...
www.ereplacementparts.com/craftsman-chainsaw-parts-c-158286_172209.html
Fix your Craftsman Chainsaw today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide shipping, no hassle returns.
Gas Chainsaw Parts ' Sears
parts.sears.ca/parts/lawn-equipment/gas-chainsaw-parts Are you looking for top quality components that could help get your chainsaw working again? You can rely on the skilled parts specialists at Sears to provide you ...
Craftsman Chainsaw Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a30b317/Craftsman-Chainsaw-Parts Looking for parts for your Craftsman Chainsaw? RepairClinic.com has the appliance parts, lawn equipment parts and heating/cooling parts you need!
Google
Jun 04, 2017 | Electric Garden
Cant stay running
What to do if your chainsaw won't stay running?
arborist101.com/what-to-do-if-your-chainsaw-wont-stay-running/
Idle ports may be plugged or blocked - This is the small ports in the carburetor where the fuel passes through when in idle. ... Vent in the Fuel Cap is plugged - If the vents in the fuel caps are clogged the fuel becomes vacuum locked. ... Starting with the High Speed screw, turn it ...
Craftsman 16" Chainsaw Fix - Won't Run - Fixed! - YouTube
? 1:32
https://www.youtube.com/watch?v=aIUVQziXBPY
Jul 7, 2011 - Uploaded by BriggsRepair
Is this Craftsman 16" chainsaw broken? Hardly. Watch this carburetor fix and how it runs brand new!
Chainsaw won't stay running - DoItYourself.com Community Forums
www.doityourself.com/.../360759-chainsaw-wont-stay-running.html
Sep 20, 2008 - Chainsaw won't stay running. Craftsman 16" chainsaw, fuel/oil ratio 40:1. Saw is 10 years old, used once or twice a season. Last used in spring ... chainsaw wont stay running
Aug 1, 2015
Craftsman chainsaw won't stay running
Oct 30, 2010
Chain saw won't stay running
Oct 2, 2006
Poulan Chainsaw - starts but won't run
Apr 28, 2006
More results from www.doityourself.com
Why won't my chainsaw stay running? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 31, 2016 | Garden
Hi i have this chainsaw as mention below.i need a replacement part.its the black cover that fits on both sides of the motor that covers the the rubber stopper that stop the motor moving.there are 2 .
Sounds like you will have to pull the cover part of pull cord there is a spring under cover it could be broken or needs cleaning and lube also spring tension could be slack and not returning cord properly or very dirty under there be careful as spring could also be broken
Feb 10, 2015 | Garden
Replace pullcord on craftsman 316.350840
I know that the starter assembly for Craftsman 316.350840 [ The 316 means it was made by MTD] this saw became became no longer available. But you can use this model number 41AY80AG983 [Remington also made by MTD] and get the same part (exception being that it will be Orange, instead of Black). Part number 753-06974
http://www.searspartsdirect.com/partsdirect/part-model/Mtd-Parts/Chainsaw-Parts/Model-41AY80AG983/0736/1503220/1303082P/00002?blt=06&prst=0&shdMod=41AY80AG983
Jan 25, 2014 | Garden
Can not pull cord all the out to start the saw
Sounds like the pull cord has become trapped round the spool. Remove starter housing and unwind the pull cord manually off the spool. Then wind the cord back on by hand. Be careful because the spool will be under tension from the rewind spring.
Mar 18, 2013 | Husqvarna 240 Chainsaw 16" Bar -free...
Have a problem with my electrical Kraftsman chain saw, the engine is running and the chain is rotating, but when I put it against the tree for cut, the chain will stop rotate bot the engine is still...
The main drive gear is slipping. This is caused by etiher worn teeth or worn bearings. If you pass the model number I can show you a diagram of where to look and what part or parts that have most likely failed. The drive gear is the weakest link but the motor can be shifting in the housing away from the drive gear. It only takes a bit less than 1/8 inch side play. The model number will be similar to this 358.341160
Most likely it is item 26 of this diagram:
http://c.searspartsdirect.com/lis_png/PLDM/P0101241-00001.png
This example is for model 358.381160
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Chainsaw-Parts/Model-358341160/0247/1503210/P0101241/00001?blt=06&prst=&shdMod=
Thanks for choosing FixYa, Kelly
Sep 13, 2011 | Craftsman 16" Electric Chainsaw Chain Saw...
How do i replace pull string on craftsman 20/14 chainsaw
Remove the cover containing the cord rewind mechanism, untie the cord's knot in the center of the mechanism and remove the old cord by unwinding it from the pulley. Thread the new cord through the hole it goes through on the outside and wind the recoil mechanism so that it has sufficient spring tension to rewind the new cord. Use something appropriate to immobilize the pulley while you thread the cord through the center and tie the knot. Slowly allow the pulley to retract and wind the new cord onto it. Replace the cover. As an aside, sometimes when the cord breaks and the pulley snaps back quickly, the rewind spring can break.
Jun 24, 2011 | Garden
Husqvarna 14" chainsaw wont start. put new plug
Try a new spark plug.If still does not fire you have a bad ignition coil.
Nov 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Craftsman gas chainsaw 18'' model 358 pull start repair
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Sep 20, 2009 | Garden
Blade wont tighten on craftsman elictric chainsaw
Sounds like the chain guides are missing.  They're flat steel parts, one on each side of the bar...Here's a husqvarna diagram:
http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF  Select side cover, guide plates.  Could be called anything by Craftsman!  If you have one of these on each side of the bar, then I'd guess you're missing washers under the nut(s).  Sears should have this available; I'm sure I have a blow-up diagram on microfische if it's an older model.
Jul 16, 2009 | Remington Electric Chain Saw
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
234 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
