CODE L3 - Office Equipment & Supplies
  • Ken Shepherd
    Ken Shepherd May 11, 2010
    you will need to give a model and make on this equipment. But I can tell you that if it's a Sharp its probably a laser error code....and fatal!
  • 51 Answers
If it's a SHARP copier
It could be a bad scanner motor or home position sensor or the circuit board that drives the motor.
Put the copier in test mode to check the motor or sensor. Press the following keys: # * C * then press START/ENTER , press 1 then START/ENTER again, Subcode 1 will test the motor and sub code 2 will test the sensor.
good luck
Posted on Sep 10, 2009
Sharp m355n error code L3-00
L3-00 means that the scanner (the light under the glass) isnt moving correctly. You can reset it by pressing clear, interupt,0, interupt, 14,1, start button. Good luck
Jan 23, 2014 | Sharp AR-M355N Grayscale Copier
Need unlock code for LG Optimus L3
how to unlock my phone lg optimus l3 free??
Nov 15, 2012 | Cell Phones
L3 or L6 chassis?
The chassis number for this DLP should be printed at the back where you will find the model number and manufacturing date code as well.
Feb 08, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Sharp AR 507 has a code L3-00 Scanner will not retun home in time
I turned the copier off completely, then turned it back on -- it seemed to resolve the L3-00 issue.
Apr 30, 2009 | Sharp AR-507 Copier
How do I know if it is L6 or L3 chassis
you need to look on the right side of the set (facing the front of the set) for a small label that says
model code...
serial number..
version..
if the version number is blank or PW01 you have the
L3 chassis.
if it says PU02 then you have the L620 chassis
also the L3 chassis has the ballast on a slight angle and the L620 has the ballast straight.
Dec 29, 2008 | Televison & Video
I bought a used Sharp AR 286 Digital Imager about 6 months ago. It has been in my garage. I tried to make copies today & got a message to call for service - code L3-00. I just want to make sure it...
L3-00 is a code meaning that there is a problem with the scanner return. You can have a look at the sensors under the platen glass and look for a connector out of place. GOOD LUCK.
Nov 30, 2008 | Sharp Office Equipment & Supplies
SHARP 1631 CODE L3
The error is for the scanner mirror home position sensor. When the scanner mirror comes back to home (start) position if the photocell sensor doesn't see it due to be dirty or faulty the L3 error will be displayed.
Hope that helps you.
Aug 04, 2008 | Sharp Office Equipment & Supplies
Error code
The L3 code refers to your scanner not moving. One thing you can check is the scanner lock, which is a clear round dial located under the scanner bed (where you remove your copies from).
I've seen that dial get bumped into lock position when copies are removed from the recieving tray. Alot of times, I'll remove the dial to avoid that problem in the future.
Apr 11, 2008 | Toshiba e-Studio162D Copier
50 people viewed this question
k24674
