Question about Toshiba Satellite A75-S226 Notebook
Can not find the settings for external display on my toshiba satellite. It first pops up asking what version i wanted, i selected only display on external monitor and now i cant change it back
  • Raman Katwal
    Raman Katwal May 11, 2010
    Hi, There is shortcut on key board just try this Fn + F5
    President:
  • 1,884 Answers
Reboot the laptop in Safe Mode and then set the display settings to old ones.
Posted on Sep 08, 2009
Toshiba satellite c675 monitor light up but not displaying anything
Hook up an external monitor to determine if you have a logic board or LCD problem If the external monitor works the trouble is with the display or its cables. You should also double check that your memory is properly installed and you may want to replace your bios battery. you will need to aquire a toshiba manual for your laptop to help you fix these issues. here is the link for finding your manual Search
Aug 13, 2014 | Toshiba Satellite C675d-s7310 Amd E-480...
Why won't my Toshiba Satellite L655 laptop connect trough HDMI anymore?
Check your settings,both bios and display,for the display priority.Either the settings has been set to inbuilt display and thus cant display on external monitors or the external monitors have been disconnected in bios settings
May 15, 2014 | Toshiba Satellite L655-S5101 Laptop
Toshiba satellite m30 screen is blank after starting!
I had the very same problem with my Toshiba LP, ended up replacing the screen, it broke. And there is nothing that you can do to fix it by yourself, unless you are a tech
Apr 06, 2011 | Toshiba Satellite L455D-S5976 Notebook
My toshiba cd or dvdram drive if i click says enter disc in drive
During boot press F8 and from the menu that will appear select the Recovery one.
Jul 05, 2010 | Toshiba Satellite Pro L300 Notebook
I cannot get my Toshiba Satellite M305-S4910 to switch its' display to a stationary monitor. Is there something I need to do besides plug in the monitor cable?
Are you in windows 7? If so, hold the windows key and press P. Select the monitor output configuration you want (being careful to make sure you can still see the screen on something).
If you lose the screen entirely, unplug the vga cable and reboot the computer.
May 26, 2010 | Toshiba Satellite M305-S4826 Laptop
Toshiba Satellite M300 screen problem
Hi, I can't guaranty this will help the problem, but for a quick try I say its worth it. On the Desktop, right click to open Personalize, select Display Settings; by adjusting the resolution it helps with the "Flicker effect" aswell, by selecting different settings, you can "view" the best Monitor Display. "If the solution helped, rating it is appreciated, thanks."
Mar 28, 2010 | Computers & Internet
Want to use a external monitor
  • Hi, once you have the External Monitor connected; go to, from the Desktop Screen, right click to open window, select Personalize. Scroll to find: Display Settings. You can make all the adjustments to correctly connect the monitor, updating drivers etc. Follow any given instruction when changes are complete. "Did this solution help?"
Feb 03, 2010 | Toshiba Satellite M35X-S163 Notebook
I want to get the screen from my laptop(toshiba) to show on a....
press Fn key 2 times set display property screen resolution to 1024*768 then apply and ok.
Jul 14, 2009 | Toshiba Satellite 3000-S353 3005-S303, and...
My Toshiba satellite Laptop L20 no sound card solution please
first of clear ur problem you want sound card i.e H/W or drivers for it. if you want soundcard then there are external souncards available in market purchase it put it in the USB port and use it.
if you have the sound card and no drivers for it then
insert ur driver cd and install soundcard's drivers.if you don't have that cd then download it from soundcard site by following ways:-
1. you can get your drivers .
just go to ur soundcard or driveers maufacturing site, click on download section click on drivers, enter mother board number and download the souncard drivers .
2. If you don't know the motherboard/soundcard drivers name and exact number then connect to internet, uninstall all the old audio drivers. then when pop up window says that new hard driver is found then click it and it will automatically install drivers from net
3. If you want to know about your motherboard drivers, then go to desktop
a. right click on my_computer,
b.then select properties, in properties tab click on the HARDWARE tab,
c.then click on the device manager tab, then select and expand the drivers like sound or video which you want to know.
d. right click on the selected sound or display drivers and select its properties.
e. select driver tab and the driver name and version will be before you
for further assistance pls call me
Thanks & Regard
Pravin jha
Great India
phno:- +91-9225600664
Jun 14, 2009 | Toshiba Satellite L20-S310TD Notebook
Toshiba satellite a215s7422 screen blackout problem, however, computer powers up and fan is running. external monitor will start in safe mode. sometimes i see the word signal on external monitor. help
Sounds like your refresh rate is incorrect
Boot into safe mode. Go to Start > Control Panel > Under Appearance and Personalization , select Adjust screen resolution ,
Selct your laptops display , set the resolution to 1024x768 , click on advanced settings then click the monitor tab at the top.
In the box below , select Use hardware default setting .
Hit ok.
If that doesnt fix it something is wrong with the drivers.
Start in safe mode with networking and get the drivers from here and install them.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1852724&rpn=PSAFGU&modelFilter=A215-S7422&selCategory=3&selFamily=1073768663&selModel=1852724%7CPSAFGU
Mar 04, 2009 | Toshiba Satellite A215-S7422 Notebook
Toshiba Satellite A75-S226 Notebook Logo
47 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
