Question about Philips Magnavox 51MP392H Rear Projection Television
What is the code for a magnavox tv to calibrate the picture, model number 51MP329H/17
Slinteriors
  • 8617 Answers
SOURCE: 51mp392h/17 model number magnavox
try resoldering the vertical output IC. That may be the problem bad solder has been known to cause that symptom in the chassis
Posted on Mar 20, 2008
SOURCE: I have a Magnavox 51" Projector TV. Model 51MP392H/17
Well I forgot to mention that when I do turn on the TV the button flashes 9 times then pauses for a second and repeats the flash 9 times over again.
Is this a error code for the 51MP392H/17 ?
Thank you
Joe
Posted on Jul 28, 2008
  • 6 Answers
SOURCE: blurry picture
You need to clean the projector lens on the optical engine using a soft cotton or, better yet, a chamois cloth. Also clean the mirror mounted inside the rear cabinet and also the front and rear of the screen itself.
If picture is still blurred then your the optical engine is most probably defective.
Posted on Dec 10, 2008
  • 298 Answers
SOURCE: I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Posted on Jan 16, 2009
ahhsoo69
  • 167 Answers
SOURCE: ware is the bulb located in the 50inch magnavox
  • hello here is what you need to know .on the location of your lamp & the right way to replace it. first thing is to, Turn off and unplug the unit before you replace the lamp.
  • Take care that no screws or other metal objects fall into the display interior. Such items could cause fire or electrical shock.
  • Do not remove the lamp except to replace it. Careless handling can cause injury or fire.
  • Do not replace the lamp immediately after the display is turned off. The high temperature of the lamp could cause serious burns. Allow the lamp to cool down at least two hours after turning off the display. display. 051021165929_314.gifthank you for useing fixya.com .
Posted on Jul 24, 2009
Hello, I have a Magnavox tv 32" model 32mt3305/17.
you should bye a surge potecter power cord.surges happens all the time and destroys electronics
Aug 17, 2013 | Philips Magnavox 27MS343S 27" TV
I have a ge universal remote. I've put in all the codes to my tv and none of them worked. My tv is a magnavox mod# 20ms34442/17 can you help?
What model number of the remote do you have? I also have a GE universal remote and I have used it on over 30 tv's and every single 1 worked. Do you do the autoscan or put them in manually?
Dec 30, 2012 | Philips Magnavox 27MS343S 27" TV
I have a big magnavox tv that all of a sudden the picture went out with only sound. I tried everything possible from changing cables and calling my cable company to see if the problem was there but no
Your flyback has failed most likely...bad new is they are nearly impossible to find, This is a known issue on most of the models below. The site Tv Repair Kits can sometimes get replacements - but its not often.
This repair kit is known to work on Magnavox TV sets with the following Chassis/Model Numbers.
DPTV305 , DPTV305F , DPTV310 , DPTV315 , DPTV330 , DPTV330F , DPTV335 , DPTV340 , DPTV345, MAG01
Model Numbers
( 43PP9202/17 43PP920217 43PP9202/17F 43PP9202/84 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920201 50PP920217 50PP920284 50PP920284F 50PP920217F 51MP392H/17 51MP3964H/17 51PP9303H/17 51PP9363H17 51PW9303/17F 51PW936317F 55PP9352/17 50PP920217F 51MP392H17 51MP3964H17 51PP9303H17 51PP9363H17 51PW930317F 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F 60PW938317F 43PP9202/17 43PP9202/17F 43PP9202/84 43PP920217 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920217F 51PP9303H/17 51PP9363H17 51PW9303/17F 50PP920201 50PP920217 50PP920284 50PP920284F 51PP9303H17 51PW930317F 51PW936317F 55PP9352/17 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F )
Mar 29, 2012 | Philips Televison & Video
Hi. no matter how i set up the colors, brightness, convergence, my screen has a yellow cataract like color. Can i clean the light bulbs or something. Mangnavox 51mp329h hd projection tv
I have a simple suggestion which will tell you exactly why the picture looks yellow.
It requires no parts or special tools but I need to know if you can follow simple instructions?
This is not an uncommon problem and if you require further help I can explain exactly what to do and what to look for.
SD TECH
Sep 16, 2011 | Philips Magnavox 51MP392H Rear Projection...
Lost my ac/dc adapter
Go to the philips-magnavox-funai web site:
http://magnavox.fox-international.com/
Use the 800 number ... tom
Apr 16, 2010 | AOMNI Corporation Magnavox 15MF605T/17 15...
Can't find Comcast remote code for Magnavox television 15MF605/17
Not every remote will control every TV. You basically have 3 options. 1) Call Comcast and see if they have additional codes not listed on their website/documentation 2) Call Magnavox and see if they have additional codes that might work with your remote. 3) Buy a 3rd party remote that works with both your comcast box and your television.
Jun 03, 2009 | Philips Magnavox Learning Universal Remote
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
MAGNAVOX mODEL 27ms3404/17 shuts down after after a few seconds. Mine does the same thing! My TV tube turns black after sew seconds. The green light stays on saying that the power is on. If you change...
first place to start on this chasss is with a known failure in the horizontal circuit. there is a capacitor 2455 and 2 transistors locations 7461 and 7463 that have caused a wide variety of failures. i would recommend replacing these components before proceeding as they could be the whole of the problem.
Jul 21, 2008 | Philips Magnavox 27MS343S 27" TV
Smart lock access code on tv
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number. If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental Access Code.
Sep 07, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Philips Magnavox 51MP392H Rear Projection Television Logo
76 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
