Question about IBM ThinkPad R50e Notebook
R50e PC Notebook Problem
I am not able to use the power adapter for recharging or for a power supply, is it my power port?
To confirm I have used the adapter on another similar laptop and no problem with the charger, I have also switched battery with another similar laptop and mine laptop works fine. How do I fix this?
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
And once you get the power socket (pin) repaired, get a Cable Retention Device like the video shows. . .
Posted on Mar 04, 2008
If the power socket is a separate section replace it else replace the motherboard. The power socket is probably loose.
Posted on Dec 10, 2007
I have a Hasee e130 notebook and it does not recharge the batteries. First I thought it was the battery but the same battery recharges on other notebooks. How can I solve the problem ?
when you charged the battery on the other notebook did you use your notebook's ac-dc power adapter unit. I would try using the other notebook power ac-dc adapter on your notebook or get a voltmeter set on DC voltage 20volt range and test your notebook AC-DC adapter produces the required DC voltage of the Notebook requirements.
Jun 12, 2015 | Computers & Internet
R50e laptop
It's probably your power jack inside your laptop. It's attached to your motherboard, it's not making a connection with the cable when you plug it in.
Check out this link
Or you might have to call a local repair shop.
Dec 09, 2007 | IBM ThinkPad R50e Notebook
The usb ports and the ethernet port do not work - suddenly happened - R50E
restore your system to a previous date and time using the system restore wizard. what operating system are you using?
Jun 13, 2011 | IBM ThinkPad R50e Notebook
Couldn't setup the wireless on ibm thinkpad r50e as well doesn't appear to be available at device manager as well network controller on device manager is not setup. could i know from where i could get the...
It appears not all R50e laptops come with wireless interface built in. This means if your model is one of those then you will have to buy a wirelss adapter and put it in the USB port or use a PCI wireless adapter if it has a mini PCI slot.
Check this site.
You will need to confirm what model type your laptop is and download the specific user manual from this site to see if there is a wireless connection. You could also refer to this service manual if it helps in identifying the actual wireless interface for your model.
Feb 13, 2011 | IBM ThinkPad R50e Notebook
ON a Gateway 7330gz why would it power up the moment you plug in the A/C adapter, yet not give any Video, and ignore the power button?
It seems that your AC adapter has no output. To confirm test it using the multitester. Check also the power cord for internal open due to frequent bending and pulling. Check the internal fuse of AC Adapter sometimes it fails due to power surge. If you confirmed that this is faulty you can check ebay.com, shopjimmy.com for replacement or on your local electronics supply.
Hope it may help you.
Have a nice day!
Thanks for using Fixya.
Feb 10, 2011 | Gateway 7330GZ (890552601318) PC Notebook
Power cord attachment into the back of computer seems worn, it wants to run off battery instead of recharging through power supply
Either Have A Failing AC Adapter, Or A Failing DC Jack
you can test the AC Adapter using a multimeter (available at any home improvement center for $6)..
The DC Jack Would Need To Physically Be Checked To See If It's Faulty... which would intail removal of all parts down to the motherboard and visually inspect the DC Jack (the port where the Charger Cord Plugs into)
Remove The Battery... Plug AC Adapter Into Laptop.. Attempt To Power On....
Nov 15, 2009 | Acer Aspire 5100 Notebook
Battery charger not working. Power adapter checks out ok. Laptop operates on battery only. 7325gz.
if it is not charging the battery will go dead.soo recharge it if it doesnt work then it could possibly be your charger.but alot of times the soldier on the input plug becomes loosened and doesnt get a connection. how did u check the chager
Oct 10, 2009 | Gateway 7325GZ Notebook
Laptop Battery Not Charging
first try in other power socket if it works then you have to replace the power adapter...
Feb 18, 2009 | IBM ThinkPad R50e Notebook
How to take off the motherboard r50e?
u need to take out the board, then use a soldering iron (very powerful one) but if you dont know how to remove a board how the hell will you replace or fix the usb port??
Jan 18, 2009 | IBM ThinkPad R50e Notebook
Not receiving power from ac adapter
Mine had a bad wire in the power supply.
Aug 27, 2008 | Toshiba Satellite A135-S4527 Notebook
IBM ThinkPad R50e Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
