Question about Vornado Air Circulator - Black
Fan stopped. Turned on and spun blade but nothing, on any of the three settings. Bad capacitor? how do I test switch or motor windings with voltmeter? Thank you, Torrey
    Sergeant:
  • 347 Answers
You can check the switch or motor by using an ohmeter for continuity test. connect the probes on each switch starting from common to no 1, 2, and so on. if the motor is okay, the capacitor is defective.
Posted on Sep 10, 2009
The fan turns on, blades don't move. The net says it is a bad motor capacitor. Mine has an LJY280A single capacitor switch. If I replace that, the fan should operate correctly, yes?
It probably is the capacitor but no guarantees as the insulation of the motor windings could have broken down or there might be another fault. Proper checking with an insulation tester is advisable.
If the capacitor is merely a start capacitor and not a start/run capacitor the motor should perhaps hum a little when switched on and then run normally if the fan blades are given a vigorous turn by hand.
There are several ways of arranging the motor circuit and some knowledge of these would be useful. You could have the capacitor tested by a local motor expert.
Capacitors bought as spare parts from appliance manufacturers tend to be very expensive. Capacitors are usually bought in by such manufacturers and replacements can be sourced much cheaper direct if the type and values and the maker's detail are present on the capacitor case, otherwise you will need the services of a motor specialist to determine the values for you if the information isn't available elsewhere.
Feb 17, 2017 | Hunter Dryers
I have a Lowes Utilitech FE50-F1 fan. I knocked the fan over and the blade cut off the capacitor from the fan shroud. I replaced the capacitor and the fan will still not turn on. I have long ago replaced...
The capacitor is used to set fan speed and rotation direction and if it shorted because of the fall, a motor winding may now be open.
It should be possible to verify this with a multimeter to check for winding continuity.
Feb 03, 2015 | Heating & Cooling
Why My Hobart A200 20 QT Mixer ML #104858 Motor Is Smoking?
I think... without knowing that motor... that the capacitor is a start capacitor, and that the start switch may be trying to "start" the motor full-time instead of switching it out of circuit after it figures that the motor has spun up. I may be wrong - that design may be a capacitor-run motor (similar to a three-phase motor) - but I'm betting it's a start-only capacitor.
If you know someone with a capacitance meter, you could check the capacitor - for both capacitance (to be sure it matches the label) and leakage. Easy way to write that one off. Alternatively, you could rig it such that after the motor's wound up you could manually disconnect the capacitor and see what happens - either the motor stops or else the smoking issue stops.
Whatever you do, don't let it smoke very long. The varnish on the windings is only so thick.
Jul 31, 2014 | Hobart A200 Stand Mixer
We have Goodman AC unit...not sure what kind. It has blown VERY cold until the last few days where it would stay a little above where I had it set. Then yesterday I realized it was incredibly hot. My...
Problem #1:Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor.
If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning systems.
Jun 11, 2011 | Heating & Cooling
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    Have a A200 Mixer, when turned on, you have to spin it by hand then it runs fine. Whats wrong
    The answer is clearly in the starting circuit which doesn't have too many parts, but depends on the type of starting circuit your mixer uses (electronic or mechanical start switch). I'm assuming your mixer isn't very old, as the old units used brushed motors which did not have starting circuits.
    The parts of the starting circuit are the motor start winding, the start capacitor and the start switch (probably electronic in your case which is a small silver box with four wire terminals on it). The capacitor should be tested with a multimeter after verifying it's not holding a charge (check with multimeter set to DC Volts, mixer unplugged, should read zero volts).
    Start winding should be tested with the meter to measure ohms. Locate the wires leading to the motor (hopefully only three wires) and you should get a reading for all three combinations of measurements (wire 1-to-wire 2, 2-to-3, 1-to-3) if meter indicates open on any of these, motor stator is bad(this is pretty rare and quite expensive).
    Electronic start switches are not very simple to test, but if the capacitor and motor test out OK with the meter, and all the wiring is intact (look closely for loose wires, burned wires, poorly crimped terminals, etc.) then it must be the start switch.
    May 19, 2010 | Hobart A200 Stand Mixer
    My lasko fan stopped working after a power outage. the motor hums but blades dont spin
    check the capacitor usually found beside the motor winding or inside the switch box of the stand fan
    Aug 26, 2009 | Lasko 3135 Stand (Pedestal) Fan
    Fan won't turn on. When I turned it on for the first time this summer, it won't blow cold air. I tried the different settings. The air compressor comes on, but the fan doesn't. Nothing happens with the fan...
    Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
    Jul 26, 2009 | Maytag M6Y12F2A Air Conditioner
    Compressor fan motor runs backwards
    Most likely a bad motor or bad capacitor. I would check the capacitor first as this is probably a $20 fix. The fact that it runs in the correct direction but at a reduced speed really leans hard to the capacitor.
    Good Luck and hope this resolves things for you. Let me know.
    May 09, 2009 | Goodman CKL24AR24 Air Conditioner
    Noisy
    Hello janeknows. The shaft of the fan motor may have a bearing gone bad. Follow these steps to locate problem. #1-turn power off by tripping the breaker, place your fingers on the shaft surrorting the blades & SLOWLY rotate the blades feeling for a catch or bump. A bump felt I suggest replacing the motor. No bump #2- remove the screws holding the cover supporting the control switches. Located among the wiring is a box with 2 or three wires. This is a capacitor. Note the info on the capacitor (1.4mf125v). Contact the fans Mgfr they may send you one for free if not visit your local hardware store and ask. Replace the unit using the wire caps in the unit or snip & strip the wire using new wire caps. Note witch wire went where. Turn power on and test operation.
    Oct 13, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
    Vornado Air Circulator - Black Logo
    183 people viewed this question
    Top Vornado Dryers Experts
    Steve
    Ian Summerfield
    Ian Summerfield
    Mack Baxter
    Are you a Vornado Dryer Expert? Answer questions, earn points and help others
