I replaced tthe motherboard on my dv9700 and when i was done replacing it and tried to power up, it powered up but the HD light showed no activity and no booting at all. HELP Please
  • nathaniel292 Sep 08, 2009
    ACTUALLY THIS IS A LAPTOP, SERIES IS THE HP DV9700 MODEL IS DV9880EE
    THIS IS A LAPTOP DV9880EE MODEL FROM THE DV9700 SERIES
    Brigadier General:
  • 3,614 Answers
Can you please specify the Model name of this device dv9700.?
There was a HP dv9700, but you said this was printer on your tag.
Let me know
Thanks
Posted on Sep 08, 2009
My dv9700 came up with startup system error in windows 7..error wont allow this to boot and telling me to replace hdd..can i repair this instead
Chances are you need a new (bigger) Power supply in it and a new hard drive. The power supply did not provide enough power to the hard drive at some time recently and the files written to it by windows have been corrupted.
Dec 19, 2013 | HP Pavilion dv9500 dv9600 and dv9700 FF...
I have a Toshiba satellite L655 - SW5096. went to turn it on but will not start. No fan, no screen. Only the power light indicator and a steady orange light . The orange light goes off if I remove the...
The orange light shows the battery is charging. It will turn green when the battery is fully charged. The white light shows there is power entering the computer.
The usual problem with a computer when there is no response to pressing the power button is that the motherboard has failed requiring the replacement of the motherboard.
If the computer is still under warranty there should be a free motherboard replacement, if not, and you are able to do the replacement, you can find motherboards for sale on various websites. Be aware that motherboard replacement for laptops can be expensive if done by computer repair shops.
Oct 20, 2013 | Intel Motherboard
I HAVE A HP PAVILION DV9700 I DO NOT HAVE A POWER ADATOR CAN I RUN POWER FROM MY OTHER PC TO THE DV9700 TO POWER IT
As long as the adapter you are going to use matches the specs of the required adapter, you shouldn't have any problems, check ebay for a replacement
Feb 24, 2011 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Alienware Aurora Desktop does not boot, has no HD activity
If the activity light on the front of the tower is not glowing than it can be an issue with the power supply of the PC. Try to open the tower and try to reseat the Power supply cables and check.
You can also try to Reseat the RAM (memory) sticks. If you have 2 Memory stick you can just try to boot the pc with the help of one stick and vice versa. If still the issue persist you can try to do a test on the Motherboard. Simply take out the Memory cards and power on the pc . if you hear a beeping noise than the Motherboard is fine and if you dont hear a beeping noise that it is a faulty Motherboard.
Jul 06, 2010 | Alienware PC Systems Alienware Aurora High...
I have a lenovo x200 just shut it down this morning and it was fine, not while booting it back; it does nothing HD light, battery and Bluetooth come on; then HD light goes off the rest stay on and nothing...
you have several possible problems :
motherboard problem or hd problem, i need to know what shows on the screen , but in the mean while , take the battery of the place and the power adapter and press the power button for at least 15 seconds, then without the battery, only with the power adapter try to reboot, if that doesn't work take the memory of and the hard drive also and repeat the procedures, if nothing of this helps, you need to replace the motherboard
Jun 12, 2010 | Lenovo ThinkPad X200 Notebook
HOW TO FIX POWER MODULE PROBLEM ON hp pavillion dv9500. The power cord is ok, but the module must be broke because the blue light goes on and off depending on how how move the cord at the connection site....
yes thia is right,and these a electronics tech. area. try to go repair shop, to change-it. Dont try to replace, bacause you dont have necessary tools. there is 6 to 8 layer motherboard, normaly you damage the motherboard, if you try.
Jan 02, 2010 | HP Pavilion dv9500 dv9600 and dv9700 FF...
HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Jun 01, 2009 | HP Pavilion dv9700t Notebook PC
Replacement Motherboard (ASUS) P4S533
try using a bare system only means motherboard, psu, processor, ram then connect a speaker, does it make any sound ?
Oct 17, 2008 | ASUS A7S8X-MX Motherboard
Compaq Presario SR1030NX fails to start
Sounds like the power supply or motherboard is biting the dust. U may consider power off, open case and clean out the dirt, check U'r connections and if the power supply smells, replace it.
Else replace the pc. When the power supply dies, it usually stresses the motherboard out and it dies later, sooner.
Jun 02, 2008 | Compaq Presario SR1030NX (DW256A#ABA) PC...
137 people viewed this question
jasbo
jasbo
