Question about Sony Walkman WM-D6C Personal Cassette Player
Have a Sony WM-D6C - Low muffled playback sound
Have a Sony WM-D6C - very low muffled sound I think I need to replace head and re-align or is it just de-magnetising I need? Have bought a new head but need advice on installation.
Thanks for looking guys
night71
  • 328 Answers
SOURCE: WM-D6C Battery holder
Because of the age of the unit, Sony will not carry that part. However, keep an eye on E-bay and yard sales and thrift stores and hopefully you can pick one up real cheap. Good Luck
Posted on Oct 29, 2007
SOURCE: Sony Walkman WM-D6C
If your WM-D6C has a serial number below 267201 (take out the battery block and you'll see the serial number sticker there) then the problem is electronic, not mechanical. It is likely due to the speed controller chip (labeled as IC601 on the circuit board), which is made by Sony and is type CX20084. This chip decides the voltage that is fed to the motor which is only about 2.4 volts, Should the chip be defective then the motor receives about twice this voltage and thus runs too fast. If you take the back off the recorder you will see the circuit board; it looks like a rectangle with a small square extra bit sticking out to the right. It is here that the IC601 resides. It is about the size of a small pinky finger nail and has 8 tiny legs down each side. Measure the voltage on pin 15 (put one voltmeter probe (+) on the second leg down on the right side (pin 15) and the other one (-) on the battery negative), it should read about 4.8 volts, which it feeds into the base of transistor (Q601) that in turn will then feed 2.4 volts to the motor (if everything is working OK). If the chip is damaged, then the voltage on pin 15 will be close to zero, and the transistor Q601 will not be "held back" and so will feed about 5 volts to the motor. CX20084 is (unfortunately) obsolete, someone in the UK sells them for about $50, but an excellent company in Hong Kong (utsource.net) sells them for $5 (plus $8 S&H). Taking out the old chip and putting in a new one is close to microsurgery, you will need a micro soldering iron (18Watt Antex), a good eye, a powerful magnifying glass and a steady hand, but it can be done - I've done it! There is a possible second reason that could cause the motor to run too fast. There is a pick up coil on the main flywheel called FG901. If this is damaged it will be open circuit and then the only use for your recorder is probably a paper weight. You can test this by going back to chip IC601 and locating pin 1 (top left pin; a small circle on the body of the chip is next to pin 1), Pin 1 is connected to the positive side of a capacitor,  C602 (0.47 microF), check the resistance from the negative side of C602 to the ground (take battery out, and use battery (-) as ground). You should get about 600 - 650 ohms reading. If you get nothing, sorry there is not much you can do about it as these pick up coils are definitely not available. Finally, chip 601 (CX20084) goes bad if you connect the batteries back to front. Good luck. Giles..
Posted on Jan 16, 2009
  • 11 Answers
SOURCE: plays too fast
WMD6C has a pitch control on the back of the unit that can change the speed of the tape, so switch it off, but if that is not the problem then inside the unit it has a servo set speed pot on the main board.
Dave, Electronic Doctors email eledocs@hotmail.com
Posted on Apr 03, 2009
caroldon
  • 17130 Answers
SOURCE: my sony wm-d6c appears to be running at double
Your set is running wild because the motor has lost the regulation.Hence you will need to replace the motor. It is also possible that the belt had jumped and got into the large end of the pulley to make the capstan spin higher. So remove and check both of these sectiions and confirm. Hope this sorrt yourr fault.Good day
Posted on Jul 21, 2010
  • 15 Answers
SOURCE: Who can I send it to for maintenance/repair?
Get in touch with me and describe the problem. I have repaired many d6c and high-end Walkman and, when possible, increase the performance. doctor.walkman @ gmail.com
Posted on Oct 18, 2010
My sony wm-d6c appears to be running at double speed can I fix this easily
Jun 28, 2010 | Sony Walkman WM-D6C Personal Cassette...
May 14, 2010 | Sony Walkman WM-D6C Personal Cassette...
My Sony Walkman Professional WM-D6C will turn on but the take-up spindle just slowly inches the tape along in short bursts, not a continious action.
Contact me at my email doctor.walkman @ gmail.com, I'll ask you some questions and some photos of the WM-D6C in his possession. We will solve the problem
Apr 23, 2010 | Sony Walkman WM-D6C Personal Cassette...
Sony Walkman cassette player/recorder will not rewind the tape
Fat chance to repair yourself! we repair that WmD6c but very hard to do!
Feb 23, 2009 | Sony Walkman WM-D6C Personal Cassette...
No sound coming out the headphones
Try the line out on the back of the unit and see if sound signal comes out there U must plug that into a preamp on your stereo the signal level is to low for the headphones to sound and if there is sound then u have a blown output amp in the headphones circuit!
Dave Electronic Doctors email eledocs@hotmail.com
Feb 15, 2009 | Sony Walkman WM-D6C Personal Cassette...
Repair to my WM_D6C made worse by "SONY" !!!
Ya, sony does not care U did not send it to them to repair? did U? We repair that model but we are not close to U
May 20, 2008 | Sony Walkman WM-D6C Personal Cassette...
Sony Walkman WM-D6C Personal Cassette Player Logo
178 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
