Question about Garmin Nuvi 660 GPS Receiver
No sound on a garmin nuvi 660 euro? - Garmin Nuvi 660 GPS Receiver
SOURCE: voice not working properly on garmin nuvi 660 - very disdorted
i have been told that voice to street is not as clear as the voice just stating turns. If it really bothers you then try voice to turn. I cant remember the setting but it should work well for you.
Posted on Jan 07, 2008
  • 35 Answers
SOURCE: garmin nuvi won't turn on
Well , do you delete or add something in your NUVI before that occured.
Need more information.
Is that a new problem ?
What is the lassfrimware update ?
Posted on Jan 21, 2008
sharcnet
  • 2130 Answers
SOURCE: Garmin Nuvi 660 - how do I get FM Transmitter firmware
Yes, you can purchase an external FM modulator like those used on IPOD's and CD players. I am using one on my Nuvi 350 and it works well. Just plug it into the headphone jack. Advice: Be sure to buy one that is crystal (PLL) controlled and NOT using a tuning dial. The FM modulators that use a tuning dial often tend to drift and they will also change frequency when you hit a bump in the road.
Good Luck!
- Jim
Posted on Jan 23, 2008
SOURCE: Garmin Nuvi 660 dead battery?
Normal 0 Garmin NUVI 660 instructions
It is pretty easy to open up your nuvi,(but not recommended by Garmin or me)...
looking at your nuvi from the back flip up the antenna. You will see two tiny torx screws on the antenna. Remove them and carefully seperate the antenna housing. Pay attention to how the antenna flex is seated because reassembling the antenna housing can be tricky. On the left bottom side the pin assembly that holds the antenna in is spring loaded. Pull the pin towards the center and you will be able to seperate the antenna housing from the unit. Underneath you will find two more tiny torx screws holding the main housing togather. Remove those two screws and you are almost home. Now you need the special plastic tool that you can get on ebay. The tool is used for opening ipods without mangling them. Gently pry the case apart with this tool. Start where ever it is easiest to get the tool in. Once opened you can figure the rest out for yourself. The battery is flat and rectangular and is seated behind the circuit bourd attached to the back cover.
Posted on Dec 26, 2008
SOURCE: Garmin Nuvi 660 lost Europe maps
Eventually managed to speak to a man at Garmin who confirmed that it was not loading any European maps because it didn't have enough spare memory to load them all. He said that he would email me instructions for freeing up sufficient memory, the email never arrived but I decided to delet all the voice languages that were no use to me and all the other language 'help' files and tried again - it worked.
At no point did I get a 'insufficiant memory' warning, which would have been very helpful, nor is there any guidance for how much memory will be required when embarking on the update. Take note Garmin...
Posted on Feb 28, 2009
How to open a Garmin nuvi 660 for battery replacement ?
Unfortunately the battery in the nuvi 660, like most garmin satnavs, is not user replaceable. To have it replaced it needs to be sent to garmin. Garmin contact details can be found at http://www.garmin.com/garmin/cms/site/us/support/supportcontact
Aug 04, 2010 | Garmin Nuvi 660 GPS Receiver
I have borrowed a nuvi 660 Euro, will it navigate
You can zoom the map out and then use your finger to navigate the map to France. When you are hovering over France zoom into a city and see if there is any detailed coverage.
You can also go into the "Where to?" menu and select A point of interest category. Then click the near button at the bottom of the screen and choose a location in France. Then complete the search and you should see POI's for that area.
If it does not have France you can get it at a good price here. Garmin Europe Mapping
Have fun in France
Jul 14, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 - Won't register
Sound like somebody has boughten that registered then return to the store. I would go back to the store where you bought it from and tell you want a new. .
Nov 23, 2009 | Garmin Nuvi 660 GPS Receiver
Ribbon cable for nuvi 660
u can get it at radioshack websites
or u can try this link above
all the gps information for 660 number model
http://gpsinformation.info/nuvi/660/660.html
Garmin support center----tomtom support center
http://www.gpscentral.ca/contactus.htm
Nov 16, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 shutting off
It sounds like your battery is defective. They can be replaced. The Motorola phone cable is not wired exactly like the Garmin, and your Nuvi thinks it's connected to a PC. Radio Shack carries a charger for the Nuvi. I have one myself.
Let me know if you need additional help with your battery problem.
- Jim
Nov 15, 2008 | Garmin Nuvi 660 GPS Receiver
Mapupdates
I'm trying to upload the new city navigator europe nt 2008 but don't have enough space to do the operation, How can I delete the existing map's that are on the nuvi 660 euro? Can I just delete the file gmapprom.img ?
Aug 15, 2008 | Garmin Nuvi 660 GPS Receiver
Stop transfering voice from Sony Ericson P910i and Garmin Nuvi 660
Can you update the firmware on your unit
my k800i sony phone had a problem synchronising and would freeze, then one day the nuvi 660 updated the firmware by itself and has been fine since, only problem being the volume, a bit low when trying to contest with large diesel engine, onboard speaker keen to distort over 80% volume
Feb 08, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
88 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
