Question about LG LRSPC2031 Side by Side Refrigerator
Freezer not shutting off / forms ice / pulled plug on freezer defrosted checked air flow/ one month later same problem
    Problem Solver:
  • 13 Answers
There is a defrost heater in the freezer. First, you will have to find the schematic for the refrigerator. If your model has a plastic cover on the top where power goes in, the schematic may be glued to the inside of that cover. Look for something that says "DEF HEATER" or similar. At that point, you have to decide whether the heater element is bad, or whether there is no power supplied to it. The latter is more likely. Take off the connector plug on the control board that goes to the heater. Use an ohmmeter to check whether the heater element is open. If it is, then that's the problem. If not, then look for a test switch on the control board to force the heater on. Press that switch, and measure the voltage at the output terminals to see if the board is attempting to drive the heater. If not, the problem might be a bad relay somewhere, or you could just replace the whole control board, at higher cost.
Posted on Nov 06, 2011
Refrigerator is hot but the freezer is cold
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 12, 2013 | Sub-Zero 650 / O Bottom Freezer...
Fridge keeps freezing
Top of Form
Sep 26, 2011 | Candy CPCA240FFK Bottom Freezer...
Freezer blowing air but getting warmer and stopped making ice. Fridg also seems to be warming up. no unusual noise.
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. But if the freezer also gets warmer it can be failure of the auto defrost making the vents choked. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Sep 20, 2011 | Amana ARB8057C Bottom Freezer Refrigerator
I have samsung french door twin cooling the refigerator is not cold enough,frezer working fine,ice maker working fine,
Top of Form
Aug 19, 2011 | Refrigerators
Sub zero 532 fridge is not cooling porperly but freezer is fine
Top of Form
Jul 09, 2011 | Microwave Ovens
Freezer side is working good refrigirator side isnt 64 degrees
Top of Form
Jul 07, 2011 | Kenmore Refrigerators
A layer of ice keeps forming in the bottom of the freezer. can chip it out and a new layer will start forming by the next day. also has a lot of frost as well. thuoght was the seal and have attempted to...
Top of Form
Jul 07, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our Refigerator is forming ice in the freezer. It
Probably has lost the defrost function and excess ice has formed clogging air flow and shutting down ice production. Remove the access panel and inspect the evaporaton department for signs of failed defrosting.
Apr 22, 2010 | Refrigerators
Thick layer of ice has formed at bottom of freezer. Cannot even pull out the bottom basket
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator model NoGC20C7C3Ewith fridge setting just on and freezer setting low following defrosting the operation seams ok but deteriorates with ice forming on the rear freezer panel and the lower...
Defrost system problem. Could be in heaters, defrost thermostat, or defrost timing circuit. Freezing in vegetable section is due to air back flow related to frozen evaporator coil in freezer compartment.
Colder air settles and warmer air raises.
Ice maker problem is separate. Bar up engages micro switch that is supposed to shut it off. Bad micro-switch?
May 27, 2008 | Maytag Refrigerators
LG LRSPC2031 Side by Side Refrigerator Logo
69 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
