Question about Acer Aspire 3680 Laptop
My power cord insert broke
The place where I plug in my computer broke inside. The computer store tells me the mother board needs to be replaced. Is there no other way?
  • 40 Answers
This part is normally soldered on the main board but if you can buy that part, maybe on ebay, it should be possible to change it. I have done that on some laptop successfully.
Posted on Sep 08, 2009
    President:
  • 1,884 Answers
If you are talking of the Computer PC then he is taking you for a ride. if it is a laptop then he is correct.
  • 109 Answers
Yes you must replace the receptical that broke if the shop is telling you to replace the motherboard it just shows you there expertice there and its not much to solder a new plug in this would be a board level repair keep looking for a shop that can actuly do this work!
My laptop shuts off after i turn it on.why
Does your laptop even begin the boot process where it displays stuff on the screen? Do you hear fans running, disk drives running, see lights, hear the cd drive click once and notice a light that comes on the cd drive door briefly when you press the power button? If not you computer either has a bad power cord, a bad dc power jack where the power cord plugs in, a bad mother board or static build up. 1) lets eliminate static buildup by removing the power cord and the battery then press and hold the power button for 30 seconds. Then replace the power cord but not the battery and hit the power button. If it boots up you had static build up. 2) Take an ink pen and put in in the slot where the power cord plugs into the laptop, if it wiggles loosely then your dc power jack which is soldered onto the motherboard needs to be replaced. 3) If the power jack is tight and when you plug in the power cord if you don't see any lights or hear a fan, disc, cd drive, then you can almost bet your power cord is bad. 4) If the power cord is ok then you have a mother board issue. Normally motherboards will give some beeps or constantly blinking lights when you plug in the power cord and try to boot up. These beeps or blinking lights will tell the technician what is wrong with your computer.
Mar 19, 2012 | Acer Aspire One Netbook 8.9" Notebook
Tip
If your computer has a black screen and not booting to desktop
Normally if the computer has the black display then follow these steps:
1) disconnect the pwr cord form the back of the computer //
2) disconnect the printer and the internet cord//
3)hold the pwr button for 1 min and then release// this is called "pwr drain" when the pwr cord is disconnected//
4)connect the pwr cord and restart the computer and see if it boots or not.
5)if not then disconnect the pwr cord again and open the side pannel of the computer//
6)on the mother board you will find the RAM (MEMORY CARD) which will be approx 6 inch long", take out the card/s and plug the pwr cord and restart the computer//
7) if you get the beep sound then the mother board is ok and if you do not get the beep sound then the problem could be mother board//
8)if getting the beep sound then fix the RAM CARD properly and restsrt the computer// it shoul boot//
note** during all this process make sure that the pwr cord is pulled out when you put your hand inside the computer or else you can get power shock..
on Jun 10, 2010 | Computers & Internet
No beep at start up
Could be a grounding issue. Remove the mother board from the case, and place on a piece of cardboard. Plug in the power supply, memory, monitor and power switch if it will reach (if not then you will need to short the jumper were the power switch plugs in with a small screw driver). Once set up, power on the mother board, you should get a no hard drive error, since we did not plug it in. If this does work, you will need to go the hardware store and pick up some rubber or paper washer to place between the mother board and the case.
Feb 22, 2012 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
When I turn My Computer on all that happens is I hear the fans on the back running really loud and a light on the back flashes green. The light on the on button on front doesn't even come on, but I know...
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Nov 08, 2010 | Gateway GT5220 PC Desktop
My computer is plugged in, but not charging even when switching out batteries and power cords
This may point to a couple of things. One is the DC adapter and the other may be the power jack or the power board inside. The jack on the laptop can wear loose. You should notice that the power cord is sloppy or moves and that the power led will flicker if this is the case. The power board does fail but it rather uncommon.
The dc power adapter (brick) might the culprit. To check you need to use a voltmeter. It takes a few seconds to check and you would know if it is good or needs replacing. Just trying to think who to suggest you take it to that would have a meter. Battery stores or electronics places should. A computer store with a tech who has a clue will have one. If there get no volts then order a new one in. If you get power at or above what it is supposed to do (printed on the label) then the problem is the power board inside. This is a bit of a pain to hunt ths down but is how you have to check it.
If it is the powerboard you need to get a repair estimate. You don;t have your model etc listed so I can't tell you the price. Some will have the power section built into the main or motherboard others will have a seperate little board. Depending on how new or old it is you may pay $35-$50 for a power board and $125-$300 for a new mainboard plus labour.
A power jack is worth $10-$90 plus labour.
My bet would be on the power brick, followed by the jack. Those are the two very common causes. The power jack on some brands is all I would look at others are a bit better.
Aug 20, 2010 | Computers & Internet
Monitor and computer were left on in "low power state" mode. Came home from work and monitor just had static-like white/black streaks. Power button lit but would not power-off. Unplugged, waited,...
Hmm, I put mine into sleep mode, bloody thing would not wake up? Anyway, if you are a DIY'er, try this, cause worked on mine, yes it is now awake cause I'm typing this diddy!
Switch off poota! Remove side panel/ STOP/ Find and put on Disposible Latex Gloves to fit!. (Static from you)?
Torch would help/ locate standby small circlar flat battery/gentle remove from seating/place were you can find, don't lose it!. If you can, but replacement, but not necesssary/ Now you will see a lot of wiring, don't worry, look for a bundle of wiring, approx 6/8 wires going into a long flat thin plug, which is attached to the mother board, it may have a small securing lug, push out of way/ Gently but firmly, wiggle plug from socket on mother board, and place to one side. Now wait. I figure any memory that is retained through onboard hardware, looses its function cause there is no charge?
Reconnect wiring plug to socket on mother board, be sure you line up all the pins to their sockets, it will slip on if you have all in line, gentle push to secre.
REplace battery, again beind care to place rightside up. (Wording on Top of Battery Facing Out)
Replace poota panel, switch on, hopfully it should fire up.
AS for Monitor, hopfully it to should kick in without problem. Before you ask, me and monitors dislike each other. It plays up, I chuck and replace. Can not be wasting my time?
Hope this solution works for you.
Nov 14, 2009 | Gateway FPD2275W LCD Monitor
Gateway 830GM power
Could be power supply, unplug every thing from the board, remove all drives, cards everything but the mem. turn it on, if you get some beeps, add your Hard drive. The power supply may not have the guts it take to run all the peripherals it used to, this test will tell you if its the board or power supply.
Jul 15, 2009 | Gateway 830GM PC Desktop
Need to install CD/DVD drive on my compaq computer 2003
to install a CD drive to the computer, you should physically insert the CD drive to the computer. then connect the power from power source inside to the computer and IDE cable came from the mother board connection.
Its a plug and play device so don't need to install anything jut the CD Rom itself to the computer.
Look for the proper place on where to put the CD drive to the computer.
Mar 10, 2009 | Computers & Internet
Computer not working, been a year now
test the cord, use it in place of the one on your other computer, if it works ok, then replace the power supply on the computer that will not start, however I warn you now, I have done computer repairs for a long time, and there is no telling what the "power surge" ate! you might replace power supply to find out the connector on the mother board was ate too. this is a trial and error thing or (process of elimination)
start with the power supply, if the cord is good, (and the cord will be fine).
Mar 06, 2009 | HP Compaq Presario V2000 Notebook
Warreny over , fix it myself ?
I don't think you'll be completely happy with this, but I'm pretty sure the DC Jack (the power plug you broke) is soldered onto the power control board. This doesn't mean it's not repairable. I've done this with some good success in the past, but you might just want to replace this entire "daughter" board. HERE'S ONE on eBay for about $75, a lot less than the $200 for the mainboard or more for a complete replacement or repair. You could try to repair the DC jack and if that $12 fix fails, replace the entire Power Control Board (PCB). I think you should take it apart and check at least. It isn't that difficult if you have patience and the right tools. You'll need a "computer" or "electronics" screw driver kit and something like a credit card to help pry apart plastic pieces without scratching them. I also found this thread on NotebookReview that talks about doing what you want to. To see what the board looks like check out these pictures: eBay: 3680 mobo1 http://i17.ebayimg.com/04/i/001/0d/e1/7ce9_1.JPG To pick up the DC Jack you'll need, check out eBay, they are around $12 shipped. HERE'S ONE EXAMPLE GOOD LUCK!
Oct 07, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
