Question about Smart Modular PYXSCAPE SV1170 17" Flat Panel LCD Monitor
Do not have a power chord. How can I get one ?
    Master:
    Sergeant:
  • 460 Answers
You can get it from computer shop.
Posted on Sep 09, 2009
The print cartridge can not move
turn on the printer then try to move it manually..
if it does not work turn it off and try to move the carrriage manually.
still does not work then do following steps...
1) connect printer directly to wall
2) remove the power chord from back of the printer and then press and hold down power button for 30 sec. release the button and plug in the power chord..
3) if still it does not work out then unplug the power chord from the back of the printer.. press and hold the pound(#) and number 6 key together. then without releasing the button plug in the power chord.. once the power chord is plugged in release the buttons.. the printer would align .. if still it does not work then replace the product as it is an issue with the carriage
Mar 26, 2011 | HP Officejet 5610 All-In-One InkJet...
Hp officejet 6310 makes loud grinding noise on right side
1) connect the printer directly to wall
2) try different wall outlets
3) unplug the power chord and then press and hold down the power button for 30 sec. release the button.. then plug in the power chord
4) then try to move the carriage manually from left to right.
5) check if any papers or any thing is stuck inside the printer or not..
6) then unplug the power chord.. press and hold the pound(#) and no 6 key together and then without releasing the button plug in the power chord..once the power button in plugged in release the button..
the printer would go back to factory defaults..
check what happens
7) issue not resolved the service the product..
Mar 26, 2011 | Office Equipment & Supplies
Hp c5280 wont switch on, its been working well when last used this morning.
Disconnect the power chord from the back of the printer. Wait for 40 seconds and connect it back and check if it is warming up or not. If not the press power key for few seconds and see if it turns on or not.
If not then check if the adapter is getting warm or not after it is connected to wall outlet.
If adapter is warming up then try another power chord and check..
If both power supply are getting warmer then problem is with printer hardware and if printer works with another power chord then replace the damaged power chord
Feb 25, 2011 | HP Photosmart C5180 All-In-One InkJet...
C309a ink level shows low after replacing cartridge with cosco refilled original HP cartridges???
1) remove all the orange tape from the cartridge properly...
2) plug in the power chord directly to the walloutlet
3) unplug the power chord from the back of the printer.. then press and hold down the power button for 30 sec... then release the button.. the plug in the power chord and turn on the printer..
check the ink level...
4) if it does not work press the setup button on the printer >>> press the right arrow and go to Tools >>> clean printhead...
5) after it is done again press setup >>> Tools >>> Align Printer.
after that is done check the ink level again...
if it still does not work follow the next step..
6) unplug the power chord from the back of the printer.. then press and hold the pound(#) and 6 key together.. then withough releasing the button plug in the power chord... after you plug in the power chord release both the buttons... alignment will continue... do not stop the alignment...
after it is done again check the ink level...
7) you can also check the ink level by pressing the setup button >>> Tools >> Display Estimated Ink Levels...
Hope this works for you...
Jan 25, 2011 | HP Photosmart Premium C309A All-In-One...
Printer keeps turning its self off after power surge 5 days ago HP2727NFS
perform a POWER DRAIN.
Steps to perform a power drain.
1. Switch off the printer and remove the power chord from the wall jack.
2. Remove the power chord, USB and any other wire attached to the printer.
3.Press and hold the power button for 30 seconds and then release it.
4. Attach all the chords and try printing.
I think that will work.
Dec 31, 2010 | HP LaserJet 2727NFS All-In-One Printer
I am missing the power cord for my Phillips R15 DVR and need to purchase a new one. Any suggestions?
Hello
You just buy one power chord which has made up with high quality meterials. That is all. The chord must be capable of handling enough current concumed by your product. A normal type power chord will meet your need. Take a power chord which has plughin compactability of your household plug point. OK.
Dec 08, 2010 | Philips DIRECTV R15
Power cord broke, where can i get a new one?
Hello
Power chords can be got from the most electronic spare part shops. Go for a good quality power chord. With more strands inside it is better. Keep a piece of power chord as sample with you when you go for it. Take a power chord which comes to the length of 3 yards or so for Tv. You just say the salesman that the chord is for Tv use. Ok
Oct 27, 2010 | Axsion Axion AXN-7200 TV
When i put the power cord on my acer aspire 9500 the light of the power cord turns off and it makes a sound like a bomb...please help
there is a problem in ur power chord please check it with other chord or else replace with a new chord if the other chord is workin or change the battery .................
Sep 16, 2010 | Acer Aspire 9500 Notebook
Power cord came out the back of the tv
1. Replace the power chord.
WARNING HIGH VOLTAGE: Do not attempt to work on your set without another person present who is trained in CPR
If the power chord is a plug in type , plug it back in.
if the power chord was ripped out , you need to repair it.
if the power chord was broken before you discovered it, you will also need to repair it.
I do mean a proper repair not just an electrical tape job.
Thank you for selecting FixYa!
azkeyz@fixya.com
Wizard Division.
Sep 24, 2008 | Televison & Video
Smart Modular PYXSCAPE SV1170 17" Flat Panel LCD Monitor Logo
125 people viewed this question
Top Smart Modular Computers & Internet Experts
David Payne
David Payne
Are you a Smart Modular Computer and Internet Expert? Answer questions, earn points and help others
