Question about Bosch WFK 2401
Bosch WFK 2401On/Off Switch
Our Bosch WFK 2401 will not stay on without holding the button. I found the parts for the front panel at http://www.partstap.com/partsearch/model.aspx?model_id=232644 with a great drawing. I was wondering if I needed the spring and the switch or just the switch before I order it. How do I remove the front panel to see which part is bad?
    Genius:
  • Bosch Master
  • 1,467 Answers
You need a new switch should be able to buy on its own note wiring before doing.. it just pops out i think..good luck
Posted on Sep 29, 2009
Code 08 on bosch wfk 2401
Faulty door switch
Aug 27, 2014 | Bosch WFK 2401
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
I have a Bosch washer model WFK 2401 and I need a new pressure switch. The repair company I'm dealing with says that they can't get the part from Bosch any longer. Do you have any suggestions for...
We own a Bosch- probably nearly 20 years old. I manged to get the parts I needed- but we live in France and I buy on-line from the UK!
I would go onto the Bosch site. You will probably find spares suppliers from which to inquire. Also I'm sure you could query the Bosch site directly.
I'm not criticizing your repair company but I will be very surprised if the part was not available from somewhere.
Good luck,
John C
Feb 09, 2011 | Bosch WFK 2401
Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Apr 20, 2010 | Bosch WFK 2401
Installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Bosch WFK 2401 hot water wont shut off even if you turn power off
I can help , If the unit is leeting water in with the power off the only thing it can be is the water inlet valve , it is the componet you connect your water line to under the unit behind the front lower panel. Tell me if you have any other questions and let me know how this works out.
Phil
Jan 07, 2009 | Bosch WFK 2401
Bosch WFK 2401 Washing Machine On/Off Switch Replacement
TRy www.espares.co.uk/bosch
or www.bosch-spareparts.co.uk
If it runs o/k with the switch held in .\then all youneed is a new switch.
Plz rate my advice.
Thanks.
Jan 03, 2009 | Bosch WFK 2401
WFK 2401 DOOR does not open anymore
where is this machine i might be able to help over the phone
262-893-4840
Apr 23, 2008 | Bosch WFK 2401
Fault Code 06
put the selector switch on the x setting and hit the start button it will tak 60 sec and the door will unlock
Apr 19, 2008 | Bosch WFK 2401
Washing Machines Logo
371 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
