Question about Pantech Matrix Cell Phone
Suddenly I can only access a-c of my contacts. The rest have disappeared and I don't get a save option when I receive a call from someone who was previously in contacts who is everyone from d-z
Kyocera hydro can receive calls but will not call out
its not your phone kyocera system is having issues and they are trying to solve the problem. for now the only thing to try is master reset. make sure everything is saved to your sd card first because master rest will DELETE EVERYTHING. pictures automatically save to sd card
save contact to sd card: go to contacts hit options and export.. after master reset you will have to go back and option import.. you do not have to remove card before reset because there is an option for that
master rest: settings, devise resest, reset, make sure you scroll down and the sd card option is not checked off, then "erase everything"
this is as far as i have gotten i dont know what kyocera does if the problem continues
Feb 19, 2013 | Boost Mobile Kyocera Hydro Smartphone
Unable to send or receive message txt pro
try factory restore option. if tis is not working then u need to format ur phone
Mar 09, 2012 | Sony Ericsson Txt Pro
Hi, I have background data and autosync both ticked in my phone's general sync settings so I can receive emails from my gmail account, but it has also autosynced my contacts so that now I only have...
This is happening not because of Gmail contacts sync. This happens due to setting in Contacts application which is not showing phone contacts.
To solve this problem, 1. Open Contacts from Menu 2. Press Menu button (first button on phone), select "view" 3. You will see option to view phone contacts, gmail contacts,Facebook contacts (if you have setup Facebook) etc. 3. Check "Phone " and you will see phone numbers also in contacts.
TIP: You can check " Only show contacts with phone number" to hide email only contacts.
Reply in case of any problem.
Jun 15, 2011 | Samsung Galaxy S GTI9000 Smartphone
I would like to send a business card to someone. How do I do that?
Hi Just Try This
1) Go to Menu->Contacts
2) Select a contact witch is you wont to send open that contact
3) go to contacts options select the "send business card"
otherwise you may type manually as given below because you don't intimate your phone model
//SCKE2 BEGIN:VCARD N:name TEL:number END:VCARD
The receiver will see the text BUSINESS CARD RECEIVED displayed on his/her. phone.
I think it may Helpful to you
There is a rate option "Was this helpful?" Yes or No.
If you are helped you can rate, that is your choice.
Jun 07, 2011 | Samsung Wave S8500 Smartphone
How do i attach photos to contacts on my samsung galaxy gt 19000. I have numerous photos attached to my contacts which have disappeared and now that i am trying to reattach some photos i do not have the...
Before you can attach a photo to a contact, you should first ensure that the number is saved on your phone and not sim card.
Then, you scroll to the number, select options, then add image to the contact.
Or, from the image location, select the image you want to add to the contact, then 'use image', select the option to use as contact image, under the condition that the contact in question is saved on your phone.
If the contact is saved on the simcard, simply select options, then move it to phone memory.
Hope that helped?
Success.
May 22, 2011 | Samsung Galaxy S GTI9000 Smartphone
How do you store a number
After you dial or receive a call, go to your recent calls. High light the number you want to add and access the drop down menu, it should give you the option to save the number or add a new contact. Or you could go to your contacts, or people, or where ever your contacts are and add new contact.
May 03, 2011 | Cell Phones
Problems with how do i delete a group of names on my text contact list
try to unlock the contact. try going to it and cycle through the options
May 17, 2009 | LG CU515 Cellular Phone
Where has my saved game (batman lego) disappeared to? I'd completed 80.8% and now can't access it.All games appear to be new!
Make sure you are using the same memory card, and the same game cartridge. Check under saved games. And are you sure someone hasn't deleted it!?
Apr 24, 2009 | Nintendo Video Game Consoles & Games
SMS Inbox Disappeared
Hello Brian, The SMS folder dissapears most probably because another program interferes with it. The same happens on some HP's with camera, where this options dissapears from menu because of some user installed programs. In your case, it doesn't have to be a SMS - messaging related program, there are some compatibility issues and programs that apparently doen't have anything to do with messaging are causing this. You should first try a master reset (hard reset) (save your data first). However in some cases this doesn't help, even if the program that's causing the problem is removed, and you will need a firmware rewrite/update. In order to perform this, or if you don't want to risk performing it yourself please contact me on the live assistance for step by step instuctions. Good luck, Bogdan.
May 10, 2007 | HP iPAQ h6315/h6365 Pocket PC
Pantech Matrix  Cell Phone Logo
29 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
