Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
My whirlpool duet front load won't run. I got an f- error code and when i went to run the drain cycle it sound like grinding coming from the pump? Now the drain cylce won't even run the machine just sits there and hummms till the error code comes back up. any ideas?
    President:
  • 1,776 Answers
It sounds like the pump. You can check the drain line for kinks or obstructions, but I didn't like the way you described the sound the pump made. Remove the hoses from the pump and check for anything clogging it, like the occasional stray sock and check the pump impeller. Make sure no blades are missing/broken and that the impeller spins freely. If you find any broken/missing blades or if you can't get the impeller to spin freely, the pump is defective. Sometimes hard objects like coins, pins, etc. can make it to the pump and damage the impeller. Hopefully it's just a clogged pump or jammed impeller. Sure sorry for your trouble and hope this helped. Best wishes.
Posted on Sep 08, 2009
My whirlpool duet front load washer is giving a F21 error code. It will not drain. When I blow into the drain hose on the back of the washer it will start draining. But everytime I run a new cycle it will...
whirlpool duet front load washer this video is on a bosch but it will help you Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not drain. It sounds like the motor for the pump is running but nothing is coming out. Whirlpool Duet washer.
It sounds like you may have a kinked drain hose or an obstruction in the hose coming out of the tub to the pump. The pump filter screen may also be clogged.
Are you getting any error codes?
Mar 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hello- I have a front loading whirlpool duet washer. I am not sure of the model number BUT.... it fills and begins its cycle and after awhile it starts to make a low grinding/crunching type noise. It...
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Jan 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool duet HT front loading automatic washer, it's not draining & last time it did this a repair man came and showed me how to get underneath and drain it, but I don't remember how
The following link explains how to access the drain pump on a Whirlpool Duet front loader to clean out the trap:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are experiencing drainage issues and cleaning the pump does not work, you may have to replace the drain pump. You will usually experience an "F2", "SUD" or "F21" error code (depending on model number) for a drain blockage problem. Since this error code occurs when the drain cycle exceeds 8 minutes, if the pump motor or impeller becomes damaged, the pump will not pump at the required volume and the error code will continue to occur. Replacement pumps can be purchased on line at:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop all of them for the best deal.
NOTE: Make sure you also check the drain hose and the inlet hose that runs from the bottom of the wash tub to the drain pump. Small articles of clothing can commonly get lodged in this area.
If you have any questions, please let me know. I hope this helps you.
Nov 01, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer giving F2 error during wash cycle, cycle doesnt finish
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet. Strange noise and F 02 error code
Feb 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Grinding noise during the drain cycle and intermittent draining
Hi, Well sorry to be the bearer of bad news but you will need a new pump fitted to this! You could have a go yourself but it can be a bit of a pain! I would be willing to tell you in detail on how to do it if you want to get a pump to fit?
Hope this helps?
Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer Making Loud Grinding Noise
not nesseccarrily your pump, possible you have a rear bearing going bad, which will sound as if a helicopter is coming through your laundry room. ( noisy pump can be the issue , honestly a better and cheapre problem to have) in order to determine if its apump problem you can remove the lower access panel and unplug the pump then start the spinn cycle, if it still loud the pumpms not hte issue.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
80 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
