Question about Sanyo DS19310 19" TV
OLDER SANYO TV
BUZZES FOR ABOUT 5 MIN. UNTIL WARMED UP
    Genius:
  • 1,694 Answers
Probable bad solder connects and bad / weak capacitors
in power circuits....look for overheated areas on bottom of
circuit board....Use ESR meter to check capacitors...T.
Posted on Dec 09, 2007
Sanyo tv Mod# dp41042 originally just went black every 15 min. Now has a red screen with a few scattered horiz lines & goes off in 5 seconds.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Feb 05, 2017 | Sanyo Televison & Video
The right 3d of my 42" Sanyo is dark for about an hour and than splits with half upside-down until warmed up after you turn it on. It seems to be getting worse.
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 27, 2015 | Sanyo Televison & Video
Front passenger side thumping at very low speeds
check if you tires have rayon cords or steel belts. this is a problem associated with the older tyres that had rayon cords as the main structure of the tyre. When left standing after running and allowed to cool the rayon belts actually took on a flat spot on the bottom and the noise lasted until the tyre warmed up enough for the tyre pressure to make the tyre round again. In extreme cold it may be the same for steel belted radials as the flat bottom of the tyre would hold the shape until the rubber warmed up .
Dec 13, 2013 | Nissan Xterra Cars & Trucks
46" LCD HD TV no picture until 20 min after being
Check the video module see if you can resolder the components, the tv have some loose connection in that video section and in the power supply.good luck.
Oct 04, 2011 | Sanyo 42 in. LCD TV
I have a sanyo tv. Slightly older. Not hi-def or New
Hi:
This may be due to the possiblity that the you are on the wrong input source, If you watch HD Channels then the input source would either be componet or HDMI input. Try changing the input source of the television with the TV's remote until you see the Channels again. IF you are not watching HDTV then the television is on the wrong reception channel for the Direct TV's box. Try channel 4 or 3 or even 73.
May 06, 2010 | Sanyo AVM-2509S TV
Suzuki sidekick transmission - wont go into drive gear until warm
I have the same issue - the car cold will not shift out of first until the trans fluids are warmed for about 5 to 10 min. did anyone respond to your question?
Bill
RGRDonovan@aol.com
Nov 16, 2009 | 1992 Suzuki Sidekick
Tv clicks off
You most likely have dry joints. If you are not competent with soldering and electronics, you should take it to a qualified repair person. They should not charge you more than £10-15 for repair.
Jan 01, 2008 | Sanyo DS13204 TV
TV turns off
replace the memory ic (IC802) if the memory no data contact me ill give you the whole data, service mode
Sep 27, 2007 | Sanyo DS13204 TV
Sanyo DS19310 19" TV Logo
124 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
