Question about Panasonic DMR-E50 DVD Recorder
I cannot open the door to the dvd to change disc and I wish to do so. Help.....
Hold down the open/close button for 1 min whilst switching on...should sort it!
Posted on Sep 09, 2009
Sanui dvd vsh combo the dvd door will not open. The plactic round spins and if i touch it the door will open
Disc loading mechanism fault. Contact any service technician. The mechanism should be taken out from the set for repair. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Disassemble procedure to many popular devices are given with illustrations.
Jan 17, 2017 | Televison & Video
My device cant open the disc tray please advise me on what to do
Electronics Corporation sells inexpensive DVD players. The DVD players, however, often exhibit problems due to their manufacture and way that they work, which must be dealt with during the course of the player's life. Knowing what these problems are beforehand can aid in resolving difficulties when using the DVD player. In some cases, it can help eliminate the problem before it can become catastrophic
The disc door is not properly closed if the Disc player display shows an "Open" error message. Check that there are no gaps in the door and use the remote to open the disc door. If it will not open, unplug the Disc player and gently pull out the disc door and then push it in. Plug the Disc player back into the AC socket.
If the DVD has not been inserted properly into the disc tray, a "No Disc" error message will come up on the display. Eject the disc and lightly flick off dust using the edge of a lintless cloth. Inspect the disc for damage. Insert it carefully again into the disc tray and use the remote to close the disc door.
Because the Disk player is inexpensive, the power supply is not of the highest quality. Having a surge protector to plug into the Disc player will help to keep the power supply from being damaged over the course of its lifetime.
Have a nice day
Feb 16, 2011 | Audio Players & Recorders
Disc door will not open
hello,
the reason the disc door would not come out is because there is a problem withe the mechanism that opens the door.
to fix this,
1. you unscrew the dvd player,
2. take off the cover,
3. plug the dvd and press open to see if the door would open, then you will see where it is getting stuck,
4. replace the mechanism that is controlling the disc door, and press open to see if the door will open.
5. once it is able to open up, you can screw back the cover.
Jun 02, 2010 | Memorex MVD2040 DVD Player
My dvd player won't read disc, the door keeps
change the motor belt charge it´s located downside the disc tray
Nov 09, 2009 | Apex Digital AD-500 DVD Player
Region Code
1. Press DVD "OPEN/CLOSE" key on remote Control (R/C) or main set to open the DVD door (note: if no disc on tray, then no need to open the door);
2. Press R/C numeric key sequentially 9735 (entry code, no display on TV), enter DVD region code setup menu.
3. Press R/C "down direction" or "up direction" key to change REGION CODE,"0" is all code.
4. Press R/C "OK" key to confirm.
5. Press R/C "SYSTEM" key to exit DVD system setup menu
Aug 08, 2008 | Philips MCD288/37 DVD Micro Theater System...
Won't eject DVD
I was able to fix this problem by disconnecting the Bose power cord from the back of the unit. When I reconnected it the door functioned again. Cleaning the disc helped avoid further lock ups.
Apr 02, 2008 | Bose (321GS) System
Durabrand pdv-702
changes are good that there is a disc stuck in the dvd player
Aug 24, 2007 | Durabrand PDV-705 Portable DVD Player
DVD eating discs
It's obvious that the DVD is stuck in the player. There's only one way to get it out! You have to open the DVD player. If you have never done this before, I don't recommend that you do it.
Apr 17, 2007 | Conia DVD8500 DVD Player
Dvd played one day and hasn't since
the belt is broken for the carocel (the disc can not change) it is plobabely stuck b/tween discs therefore it keeps opening and closing saying error . eventually it turns off. can be fixed with a small elastic goody hair tie w/o metal clasp
Feb 11, 2007 | kawasaki SVP500 Multi-disc DVD Player
Panasonic DMR-E50 DVD Recorder Logo
96 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
