Connecting multiple non digital television sets to antenna.
I have a question please. I have stopped watching commerical television because the networks have made it so incredibly annoying with all their promos, text on the screeen and the rest of the irritating government controlled garbage they do. The annoyances far outweigh what little enjoyment there is in today's politically correct programming slop. I plan to have my cable disconnected shortly. I only watch DVDs of classic shows made before television went south. I have multiple televions connected to a central network and wish to receive local off the air channels, such as weather, through an antenna for emergencies. I have seven non-digital televions connected. My questions is this. I know I will need to somehow convert the signal to each set to digital, but if I put the converter at the distribution point in the attic I would have to go to the attic each time I wanted to change the channel, since that function is done at the converter box. How can I overcome this?
  • 93 Answers
The only way to accomplish it your way, would be to buy a digital control unit made for apartments & hospitals. logical way is buy inexpensive individual converters. best i can come up with.
Posted on Sep 10, 2009
How do I watch normal tv on my audiosonic television ?
That depends upon which source your "normal" TV is connected. If you have a cable box using a coax cable, then you will either select the DTV source if the cable box uses digital output or a digital over-the-air antenna, and ATV source if the box is using analog signals or if you are using an analog over-the-airwaves antenna. If you are using a cable box but have an HDMI cable connecting it to the set, then you need to choose HDMI1 or 2 as appropriate. If you have a box that uses the red-black-yellow RCA cables, then select the AV input. Remember that for ATV and DTV inputs from a cable box, you usually have to tune the set to either channel 3 or 4 and use the box to change the channels.
Jan 05, 2016 | Televison & Video
HOW TO STOP NON CABLE TV FROM FLICKERING
Get a better antenna or if possible a outside one--set can only deal with the quality of signal that it gets.
Dec 21, 2012 | Philips Televison & Video
How do you change the settings for non cable tv
Just press the input button untill the antenna is highlighted press ok and then run the auto search feature to store any available channels.
Dec 15, 2012 | LG 42LC2D 42 in. LCD HDTV
How do you connect the antenna and get channels to work?
First make sure that your Input is TV. Use the Input button on the remote (to the right of 0) or on the side of the TV (lowest button). To watch OTA channels, after connecting the appropriate antenna for your location with a coaxial cable to your Antenna In port, press Menu then use the arrows to select the Setup submenu. Press Enter to access the submenu and select Installation. Then select Terrestrial and then Input Configuration. Here select Antenna as your input. Press Enter to save. Then scan for channels by returning to the Terrestrial sub menu and select Channel Program to scan all available channels.
Since digital signals are either sufficient for your tuner to interpret or give No Signal, you need to select your antenna and point it with care. Go to anntennaweb.org or tvfool.com to get information on the stations that you should be able to get in your location. Antennaweb assumes an outdoor antenna but still gives a conservative list of available stations. TVfool gives stations depending on the color code of the antenna (indoor, outdoor, amplified) and their directions. If you are sharing the antenna signal with multiple TVs, you may need an amplified splitter. (If you do have an amplifier, you may want to test removing it from the line and directly connecting the 37HL17 to the antenna. When amplifiers get damaged they can turn into signal filters which block the signal completely.)
If you have the correct antenna, check if another TV receives the stations. If so, you may have a bad tuner on the TV. (Some TVs have better tuners than others and pick up the stations even with lower signal strength.)
I hope this helps.
(I use an outdoor antenna and antennaweb indicates that I should only get the stations from 10 miles away. I actually get those from 30 miles away as well. When I set up a neighbor's TVs with indoor antennas, one only gets the stations 10 miles away and the other gets the stations that are 30 miles away. The two antennas couldn't be rotated to the same direction.)
Nov 09, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
RCA HD52W59 HDTV Plug in digital antenna into air antenna input then run channel scan =0 channels What should I do next??? Mike
Make sure you are connecting the digital antenna to the digital antenna input on the back of the set, then rescan. Most over the air Tv signals migrated to digital transmission and therefore the analog input is mostly for older analog devices. If you still do not get any channels, then you need to make sure the antenna you are using is rated for reception in your area. You can check for proper antenna size and channels available here,http://www.antennaweb.org/aw/welcome.aspx
Feb 08, 2011 | RCA HD52W59 HDTV Projection Television
Connecting Lg HDTV to Onkyo non HDMI receiver
For a list of over-the-air digital TV stations you can receive, as well as antenna recommendations for your location, enter your zip code in AntennaWeb's mapping tool.
Dec 12, 2010 | LG 47LC7DF 47 in. LCD HDTV
Is my ILO 42" "EDTV" plasma ready for just a regular antenna?
No, it doesn't have a digital tuner. If you want to watch digital channels you will have to acquire a digital set-top box and connect it to the tv thru the av inputs.
Jan 16, 2010 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
HDLCDVD2600
The HDLCDVD260 is digital. Change the signal type, in the menu, from CABLE to AIR, then run the automatic search to program in your channels.
Feb 23, 2009 | Sansui HDLCDVD260 26 in. LCD Television
PROBLEM WITH GETTING LOCAL hd CHANNELS
You need to have a set top box.
By law, as of March 1, 2007, almost all televisions should include a built-in tuner (called HDTV, digital, or ATSC tuners) that can receive high-definition programs over the air by simply connecting an antenna. Your HDTV doesn't have such a tuner, you'll need to connect an external tuner (or cable or satellite box) to watch high-definition programming. External over-the-air HDTV tuners currently cost at least $150.
Nov 14, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Red / Green issue when connecting Mits DVD to Mitsubishi TV
Convergence problems, look in menu and find manual conver. and read for more info goto ctechnicians.com
Dec 22, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
