Question about Sony DSR-25 Mini DV VCR
Sony dsr-25 switches on, goes into stand-by, then won't start up
Our Sony DSR-25 powers up (green light on power switch), then as normal, it goes into stand-by mode straight away (red light on power switch), but won't then power up fully when the power swich is pressed again, or if you try to insert a tape. Any ideas?
There is a "Key INH" button on the front. You want to turn it to "off".
Posted on Feb 23, 2010
  • patsyconway Nov 13, 2010
    Yes I had this problem and on swtching to "off" the deck came back to life
    Patsy in Ireland
    Thanks
Dv-cam dsr 80p error 09-209
This error 09-209 .It a problem with ur upper compartment,The tape did not go till the end of senor.
The best will be open upper compartment un roll manual at normal position.Then put back n power and check with menu mode
May 07, 2014 | Sony DSR-45 Mini DV VCR
Error codes c 31 70 of sony dsr 45ap
U can do one thing check the switch at the front of DSR is in remote or not. If it is not then.Then press the reset switch is just below the the LCD. or Press eject button with pressing power supply .
Jun 27, 2013 | Sony DSR-45 Mini DV VCR
I have just connected my very old SONY DSR-PD100AP camcorder to my acer aspire 3810T computer (running on windows7) via firewire and USB. As you might have guessed the computer doesn't recognize the...
switch off then on the power of the camera, make sure the camera is in vcr playback mode check if the camera is compatible with windows 7 go to your cameras website and download latest drivers
Mar 09, 2011 | Sony Dvcam DSR-PD100 Camcorder
How do you use free run on a DSR-25 Sony Deck?
Read chapter 3 (time code) of your users manual. It outlines the settings for using time code; "free run" means that the time code advances all the time, not just during recording.
Feb 24, 2010 | Sony DSR-25 Mini DV VCR
Sony DSR 25, error code C3140. Any advise. Only comes up when tape is inserted.
FG fault when starting drum.
It’s very possible that you have a bad drum motor.
Dec 27, 2009 | Sony DSR-25 Mini DV VCR
DSR 25
C:31:23 on a DSR-25 indicates a supply reel problem, most likely caused by a defective cassette housing. Best repair solution is to send it to an authorized Sony repair center.
Feb 26, 2008 | Sony DSR-25 Mini DV VCR
Jamed tape
This happens often in my business. Sony DSR is the most delicate cassette compartment out there. It also sounds like the unit is in auto off mode(electronic proublems as well). Please for your sake take this unit to Sony or some one qualified to repair this. You should expect replacement of the compartment and what ever damage occured while removing the tape. Parts for these decks are not cheap, If you had taken it to a service person with the tape stuck inside the monitary damage would far less. The one good thing is this is a consumer unit, if it where a DSR 1500 two models up it would pro and they share parts price for repair x3 across the board.
Dec 17, 2007 | Sony DSR-25 Mini DV VCR
DSR-1800 Lost Lock
This error 07.042 means Detected the abnormal capstan speed.here what u have to do go to maintanence menu.and check the capstan speed
Sep 28, 2007 | Sony DSR-1800 DV/Mini DV VCR
Sony DSR-1800 Lost Lock
check the condition of the pinch roller. a bad pinch roller can cause this problem - a tape plays for several minutes, then has problems. what happens is the tape slowly moves up or down on the roller instead of traveling in a straight path. this is caused by the roller becoming worn or glazed and not being able to provide traction to pull the tape through.
Sep 24, 2007 | Sony DSR-1800 DV/Mini DV VCR
Video signal into VCR
you have to select to switch from comopsit to s-vhs for the video input in your sony slv -n55 to get the video reached to it regards please don't forget to rate ,thx
Oct 15, 2006 | Sony SLV-N55 VHS VCR
Sony DSR-25 Mini DV VCR Logo
409 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
