Question about Canon IXUS V2 Digital Camera
The lens of my Canon ixus camera was not aligned becaude it was dropped.
  • 109 Answers
Ok sound like you need it replaced or repaired good luck!
Posted on Sep 08, 2009
I was taking photos when suddenly my Canon PowerShot SD 1300 IS IXUS 105 read "Lens error. Will shut down automatically. Restart camera." Then the screen went blank. The lens will not retract....
There is something wrong with your lens barrel. It can be anything from some sand/dirt that got inside in which you try using some canned air to blow out the particles while continually turning it on and off. Usually what it is from is the camera being dropped, even if it is in a case or inside a bad. The jostle or direct impact of the fall will break some small gears or tweak the lens off of alignment. If it was from an impact then you lens barrel needs to be replaced and in that case the repair cost are usually as much as getting a new camera. You can send it into Canon and get it repair for a flat rate. Sorry about your camera.
May 25, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Can you help got a canon cp900 camera i drop it and it saying lens error restart camera what do i do
Sorry to tell you the the lens is out of alignment. This happens quite often (had the same happen to me). These end up in the repair shop or getting tossed in favor of an ebay or craigslist replacement due to the cost to repair. Good luck.
Feb 11, 2011 | Canon Digital SD900 / IXUS 900 Ti Digital...
Canon Camera Error E32. Camera Error Camera will shut down automatically. Please restart your camera. Please help me. I am using Canon Powershot
The most common problems in these small tiny cameras is the lens alignment. If you drop the camera with the lens extended this alignment will ****. If you are a handyman you can fix it by yourself by oppening it inside and realign/putting the lens in right position. Sometimes you can do that by forcing them to extednd manualy but that is very risky. If not handyman I recomand you to take it to a repair shop.
Jan 27, 2011 | Canon PowerShot SD1400 IS IXUS 130...
It dropped, we got all the pieces but the lens has two lose springs and the lens protectors won't close or open any more
The lens mountings have come out and hence the shutters have moved out of mechanism and alignment. It will be necessary to open the camera and start to refix them. If it had fallen on the lens then there is a possibility of the the hood mounting been damaged. If so you will need to fix this out but if any plastics are broken then the alignment may not set well . The best is to approach a camera repair centre preferably Canon , and try to piece it , this will be much better than to assume the fittings. Hope you try this out. Good day
Aug 12, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon iXUS 750 approx 3 years old. Getting E18 message. Lens will not retract, unable to take photos. Camera not dropped.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 12, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
I dropped my camera and the lens won't retract. The screen reads lens error restart camera. Even though I have removed the battery to restart the camera, it won't correct its self. The lens stays out.
When you reset the camera you should be able to hear the gears of the camera lens turning. The problem is that the lens is out of alignment so the lens can't slide back in. As the gears are turning, straighten out the lens (you might have to try forcing it in different directions if it's not obvious which way the lens is bent) and it should slide back in. You obviously want to be gentle enough to not break it, but sometimes you have to use a little bit of force based on the severity of the drop. You also might need to try a few times since the gears will only run for so long before stopping. I have fixed a few cameras this way but if the lens is bent too far out of alignment you'll have to get it profesionally fixed.
Apr 27, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
We dropped our canon ixus 50 digital camera and lens jammed
You didn't mention what exactly is the problem. But please review the posts on the following blog, as they cover the most likely problems to result from a dropped camera to include lens errors, shattered LCD's, and non-starting cameras:
http://camerarepair.blogspot.com
Feb 02, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Lens error
Have same problem as above. Apparently the gears in the lense slip a tooth, they can be re-aligned but this involves taking out the barrel, my question is, how do you do this as I don't want to pay Canon the AU$250 for a new barrel.
Oct 23, 2008 | Canon IXUS 860 IS Digital Camera
Canon IXUS V2 Digital Camera Logo
59 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
