Question about Kenmore Elite 45986 Front Load Washer
Water in tub
Everything seems to be working ok, except when I come back to the washer after a few hours there will be water in the tub. This is after I have done a load of clothes and the washer is empty. Water seems to be leaking into the tub, about 4 inches of water
  • 574 Answers
More than likely your water inlet valves aren't closing shut. I would check that first
Posted on Sep 08, 2009
Why does washer not complete cycle & lid not unlock?
Probably leaked thru tub bearing on tub and got into cluth, ur lucky to have this washer for as long asyou have costs more to repair than replace either way if that your problem
Jul 12, 2014 | Maytag Neptune FAV6800AW Top Load Washer
My washer fills the tub, but when it goes to next cycle just hums
Your motor has failed.
Remove it from the washer to have it repaired or replaced.
Thanks
:D
Jul 20, 2009 | KitchenAid KAWS850L Top Load Washer
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
One day old washer,WPGT9150HWW, keeps saying Er-4 and refuses to continue to rinse and spin the clothes. What is wrong with it? Also the water is running into the tub very very slowly! The hoses are...
remove both fill hoses ck for good flow through hoses if flow ok look inside connections on back of washer screens in fill valve may be clogged with sand/rust or other debris
Jul 09, 2008 | GE Washing Machines
Hotpoint Dishwasher
have you tried adjusting the feet on the front of the washer so it is tilted back slightly .This will stop the water from coming over the little lip on the front of the machine. Some dishwashers also use a little amount of water in the bottom when drying asthis helps to curculate the heat ; leave the washer to complete it's cycle and it should beep to let you know when it is finished
Dec 09, 2007 | Dishwashers
Washer leaking water from bottom
Probably a main tub seal, big job!
Nov 16, 2007 | Maytag MAV7600 Top Load Washer
Another flood. GE washer
The water sound is normal. There is a solution in the top of inner tub for balance. Is it overflowing...as in not stopping the fill cycle? If so check to make sure small hose is still attached to outer tu at bottom left front. This dome that it connects to can become filled with scum and causes the unit to not know that it's full. This causes flooding. You can try removing hose and cleaning out with thin wire. Sometime only fix is to replace outer tub. Again, this is only if overflowing!!
Another possibility is a bad break allowing outer tub to spin in agitation. This throws water up over sides of tub. Monitor unit when agitating to see if outer tub picks up speed and starts to spin. It is normal for it to index.
Nov 08, 2007 | GE WDSR2080D Top Load Washer
Hotpoint WMA76s
It sound that your problem is cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear tube first from any obstruction, In case it doesn't help,you should replace the level switch unit. Good luck !
Jul 30, 2007 | Hotpoint WMA76 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
63 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
