Question about Troy Bilt 5.5hp Self Propelled Mower
Honda harmony self propelled cable snapped at end
Self propelled cable snapped at drive train need to know how to fix
  • 388 Answers
Get a replacement cable, part number should be in your user manual...when you get the cable it should have directions on how to replace.
Posted on Sep 08, 2009
  • bulldogchief
    bulldogchief Oct 11, 2009
    Gee, maybe I should have just given you the part number or even better yet just come to your house and repaired the existing cable for you. Thanks for the 2 star rating.
How to attach drive cable 406259 on husqvarna model 917.376820
This is hard to explain over a computer. I found a diagram of your make and model. I would try using a long end needle nose pliers to attach spring. I hope this helps. Good luck!
Dec 07, 2013 | Husqvarna 7021R 21-Inch 160cc Honda GCV160...
Honda Harmony mower starts but will not stay running
rebuild the carberator. easier said then done huh. anyways, thats your only soluation. hope this helped you
May 28, 2010 | Honda Garden
I have a toro self propelled lawnmower. Ireplaced
the spider gears are in on the wrong side more less like you put the rear end in backwards
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
Honda Harmony self propelled not propelling. Belt is fine. Cant find adjustments
Do you know for sure that the belt is not stretched. Make sure also that it is on the pulley correctly and the pulley is spinning with the shaft you also might have spun a key.
Oct 08, 2009 | Garden
Honda Harmony II HRR216TDA drive clutch cable snapped. Need advice on how to access transmission box to change cable. Owner's manual does not address this level of repair and schematic obtained from local...
First put the machine on the side with the muffler facing the floor . Right behind the rear wheel you have a 10mm bolt that you have to remove and look for another 2 10mm bolts holding the plate that you remove the first bolt (one should be at the bottom and the other one on the side) .
Slide that plate out of the machine and now you be able to see the belt that goes to the transmission and also the drive clutch cable.
Hope this help .
Aug 23, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Apr 29, 2009 | Garden
Honda Harmony mower, self propelled hydrostatic, wheels lock up when pulled backward. Going forward no problem.
If i remember correctly, under each drive wheel, there is a small gear, and under each gear there is a small metal rod that is what the transmission uses to propel the mower...it sounds like the rods either have dirt on them or they are just stuck and can not move to allow you to pull it backwards
Apr 25, 2009 | Garden
How do you replace the forward / reverse cable?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=661987 How do you replace the forward / reverse cable?
Posted by HANDYBILL on Jun 10, 2008
I don't know how the end fits back on the replacement cable.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover U6437-900 / U6439-900 Windtunnel Vacuum. There is a hook on the bottom of the vacuum and @ the top by the handle as well. You may what to get a schematic or owner’s manual to see how they hook up because of the newer and different Model #’s for Hoover. The Hoover Self-Propelled works on when the handle is lower to a comfortable position then the self-propelled drive may just need and adjustment. There is a self-propelled rod that controls the self-propelled feature and it either needs adjustment or replacement or the part that hold it may be broken but either one can be fixed. So feel free to contact your local vacuum cleaner dealer with questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Accessing self-propelled cable
The first thing to do is replace the flat belt (38528035), this belt will stretch after a short period, it is the one that drives the drive mech. Also the cable may have broke, if you look down on the right side, you can see the cable, did it break there or is the #34 actuator(#43143046) that the cable attaches to broke. The cable (#43211019)sometimes breaks on the upper end #14, take the handle off and you will be able to tell.
Mar 02, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Troy Bilt 5.5hp Self Propelled Mower Logo
1,440 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
