Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a 3 yr old frig/freezer, GE Gss25IFRFWW. Both Freezer and fridge has stopped working. Any ideas?
catriver
  • 878 Answers
SOURCE: GE side by Side Fridge
froggy, First check the back panel of the freezer section and see if you have a big frost build up. If so, you probably have a defrost problem, heaters more than likely. If there is no frost build-up check to see if the fan in the freezer (evaporator fan) is running. If that's ok, next would be the automatic damper. Have someone unplug the refer. Open the refer door and listen for the damper door to open when someone plugs the refer back in. If thats operational, next would be the thermistors, you would have to ohm them out to see if they are in range. Seldom is this the problem. Check these things out and get back on what you find. Catriver..post back.
Posted on Apr 04, 2007
  • 37 Answers
SOURCE: SIDE BY SIDE Frig & freezer
hurlsdad.
Sounds like a noisy evaporator fan. Take the shelves out ot the freezer then take the panels on the back wall of the freezer off. The fan will be there. Then you will know for sure thats the source of the noise. When it is time to replace it...easy fix. (few screws) Here is an excellent source for the part..www.repairclinic.com. My favorite place for appliance parts.
hope this is helpful,
handiman518
Posted on Jan 16, 2008
SOURCE: GE frig just starting leaking water at the bottom of the freezer side door
The water on the floor below the freezer door is due to an inadequate door seal. The door is not closing completely, either a foreign object at the bottom, or more likely, the freezer door gasket needs replacing.
Posted on Aug 25, 2008
  • 378 Answers
SOURCE: Freezer works fine but frig does not get cold at all
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section ( mostly on SxS refrigerators ). For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermister and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
*One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
New link from Appliance Repair Aid on how the wiring circuit works for a frost free fridge, the link is here.
On a frost free refrigerator, the cooling coils should be in the freezer section. On a SxS style refrigerator the coils will be behind a cover on the back wall.  On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. A ball of ice on the coils and the rest of the cooling coils are bare or only a few coils frosted a little and the rest are bare is an indication of a system problem. Example picture oneexample picture twoexample picture three. System problems may be a leak in the refrigeration tubing, an inefficient not 100% pumping compressor.
Posted on Apr 03, 2009
stephanos18
  • 144 Answers
SOURCE: GE Profile side by side freezer not working at all. Fridge ok.
Is the fridge side working? If not try turning the defrost timer dial until it clicks. If it now goes you need to test the defrost circuit as there's still a fault but it'll go for 12 hours untill it trys to do another D'frost. If this doesn't work try bypassing the thermostat. cheers
Posted on May 15, 2009
Frig is about 3 years old and the regular area does not get cold but the freezer still works, any ideas
Make sure your freezer is not over loaded There are vents between freezer and fridg if they are blocked fridg can't get air .
Mar 21, 2016 | Refrigerators
@15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
May 15, 2010 | GE GTS22KBP Top Freezer Refrigerator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Mar 30, 2010 | GE GTS22KBP Top Freezer Refrigerator
8 yr old maytag msd2758drw side by side isn't freezing
If the clicking noise is comming from the rear of the frig it could be your compressor trying to start. The motor would be the fan in the freezer running. That part would be normal.
If it is the compressor it could be replaced but if it were me I would buy a new frig.
Dec 29, 2009 | Refrigerators
Fridge running but not cooling
It sounds like you are having a problem with your defrost cycle. If your unit either does not go into defrost, or you have a defective defrost componet, it will cause your evap. to freeze. Hope this helps
Sep 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridge is not cooling but freezer is fine
Yes ! in most french door bottom freezer units there is a fan in the freezer behind the back panel that supplies air to the freezer as well as the frig. When the DC motor on the fan wares out the rpms reduce to the point that the volume of air supplied to both components is reduced to a point that the fan will support the freezer but not the frig. The price of the fan motor alone is around $80.00, if all of the components for the fan are replaced the parts will run about $200.00, if you are not going to do the work yourself it will probably cost in the neighborhood of $300.00 parts and labor.
Jul 12, 2009 | GE PDS22SBRLSS Bottom Freezer Refrigerator
FRIG DOEN'T GET COLDER THAN 49, WHAT COULD BE THE PROBLEM,FREEZER WORKS GREAT (GE PROFILE) ABOUT 2 YEARS OLD-
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp control. Make sure the fan is running when the compressor runs. Make sure the vent(damper) opens and closes as you adjust the fridge temp control.
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frig side is not cooling.
Check if there is frost on the back wall of the freezer, if so it is not defrosting. Many GE fridges need a new defrost heater every couple of years. If it's not defrosting, you can get by for a while by unplugging the fridge and leaving the freezer door open for 24 hrs, then plugging back in.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
87 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
