Question about Acer Aspire E360 PC Desktop
Thank you so much, but Im not really getting the computer to boot up so i could get into the settings on my Acer Aspire ASE60-U-A3503 PC Desktop computer. Like I said, The VGA connector when connected to the CPU is telling me no signal. There doesn't seem to be a connection, I;m not seeing anything on the monitor other than when the two are connected no signal and when I disconnect, its saying that a cable is not connected. Black/blank screen no beep or nothing when i turn on computer. What is my problem
  • 3,153 Answers
If you have more that one connection for the monitor try one of the others.
This happens frequently when people add video cards and forget to disdable the onboard one or maybe swap to the onbaord one and forget to turn off the extra card.
Posted on Sep 08, 2009
Pc doesn't boot stops at set up
Your computer is having some problems at POST. Try removing one of the memory dimms you have installed. In case you have one leave it like that and remove Hard Drives, optical drives, any usb devices on the back and try again. In case it boots start attaching the hard drive and try again.. if it boots, add the optical drive and so on until you get the failure.
I hope this helps.
May 06, 2010 | Acer Aspire™ T180 PC Desktop
Acer Aspire SA80 desktop: Trying to recover PC to Factory Setting
The error your getting means leaking memory,, replace the rams and it will complete restore..
NTLDR is part of the booting system of the computer..basically the computer cant find the file..
Contine with the system recover after you change the rams,, you'll be fine..
Mar 12, 2010 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
My computer froze and then turned off and won't come back on
You can try clearing the CMOS or resetting the BIOS settings to default first, then see if that helps. Then you can try repairing your operating system by booting from your Windows XP/Vista/7 disc.
Mar 08, 2010 | Acer Aspire™ T180 PC Desktop
Forgotten user password
yes you can but you will loose all information on the computer. Try booting it up in safe mode by pressing F8 right after the acer sign soon as you turn the laptop on.
Jan 04, 2010 | Acer Aspire One PC Notebook
Im trying to put my pc bak to factory settings but the disc will not auto run
For that you need to SEt first boot device as your cd or dvd rom in bios.
When you power up the computer press F1 oe F2 or "del" key to enter in bios .
Then go to boot option then set first boot device as your cd or dvd rom then save settings and exit.
Then resatrt if your recoveri disk in rom then your computer boot with it.
Let me know if you need more assistanse.
Thanks.
Sep 26, 2009 | Acer Aspire™ T180 PC Desktop
My computer is an Acer Aspire ASE-360-U-A3503 desktop computer and I still cannot get the power up button to shut off no matter how long i press on it. Then the monitor cable connector on the CPU is not...
You seem to have two problems here: The power button and the video connection.
It should take 4 seconds of continuously holding the power button in for the PC to shut off, unless the settings under Power Saving say that doing this action should have a different outcome. Check your settings. If all is correct and you still cannot turn the machine off, you may have a deffective toggle switch. This is something you can get at Radio Shack or other electronics store.
Regarding the video connection: There's a set of buttons on most monitors where you can choose the input source. Your monitor has probably been set inadvertently to receive a DVI signal while it's connected via a VGA cable, or vice versa.
Sep 08, 2009 | Acer Aspire E360 PC Desktop
Acer Aspire M1100 desktop will not boot or respond
sounds like a motherboard or HD problem, If you can try the HD in a different pc to see if it can be recognize, also don't forget to setup you pc to boot the HD first.
Jul 03, 2009 | Acer Computers & Internet
Aspire AM1201 does not boot up.
hi im josh in cebu phil. try to enter bios set up.go to power menu.then try to change the setting of power loss to shorter time then save the changes then restart your pc. good luck.try to txt if problems continue.
Feb 16, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Acer Desktop won't boot after recovery
Why not use your new hard drive as a storage disc. Reconnect your old hard drive as it was before. Hopefully it will boot the computer again. If it does, shut down the unit. On the primary bus, set your old HD as master & the new HD as slave with jumpers. Boot the unit & hopefully you will now have a "c"&"d" HD showing in My Computer. Remember that your are dealing with Windows & what should happen & what really happens can be two entirely different things.
Dec 14, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire E360 PC Desktop Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
