Question about Garden
Won't start after replacing the cracked primer bulb with a new one. McCulloch Gas Leaf Blower Model BV320
  • Anonymous Mar 17, 2014
    model bl150
  • 148 Answers
Have you tried cleaning the carb? If not take some carb cleaner and spray into the carb inlet and outlets (gently inserting the nozzle). After that see if it will start.
Posted on Sep 08, 2009
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
I have a blower/vac made by McCulloch that won't start! I tore the carb apart & cleaned it! Got it started but w n rev up! Turned I&H screws all t w in & bk out now won't start! help!
McCulloch 2 cycle leaf blower vac - YouTube
? 3:40
https://www.youtube.com/watch?v=skwugvObHtU
Dec 1, 2013 - Uploaded by Alan Marshall
McCulloch 2 cycle leaf blower vac. ... Your brand new leaf blower won't start? Try this ... starting contest echo pb251 vsmcculloch leaf blower.
cold start of my mcculloch leaf blower. - YouTube
? 4:24
https://www.youtube.com/watch?v=MgfmIezh65c
Mar 13, 2010 - Uploaded by keepin'itcountry
cold start of my mcculloch leaf blower. ... Your brand new leaf blower won't start? ... starting contest echo pb251 vs mcculloch leaf blower.
McCulloch won t start Leaf Blowers Questions & Answers ...
www.fixya.com > Forum > Tags > won t start > Leaf Blowers
McCulloch leaf blowers won t start related questions and answers. Ask your McCulloch questions. Get free help from leaf blower experts.
Nov 07, 2015 | McCulloch Garden
My Ryobi 4 cyl 30cc leaf blower just quit starting. Has always started perfectly, but now it just wont start.
replace spark plug.if spark plug okay problem could be carburetor or air leak at fuel lines or check primer bulb for crack which cause air leak.any breaks in fuel line or primer bulb cause air leaks fuel system cause carb not get fuel run engine.
Sep 20, 2013 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
I have an mcCulloch 325bp back pack blower gas wont come to in the primer bulb
Try replacing the fuel filter in the tank, if this is bloced it will not fill the bulb
Jun 16, 2012 | McCulloch Carburetor 322410-01 Blower 280...
Gas is leaking from the leaf blower.
Unless the tank has been cracked, it has to be one of the following: Broken lines, split primer bulb, unsealed fuel cap, bowl gasket of carb. I would start with the lines and bulb since they are the ones usually at fault..Good luck...Lee
Sep 04, 2009 | Echo Garden
Gas primer bubble cracked. How to find replacement
The part your looking for is called a "primer bulb" and is relatively inexpensive (under $3).
The exact bulb you need depends on the model chainsaw you have. Lacking a model number, I've provided a link to a site where you can verify which model McCulloch chainsaw you have and thus, which primer bulb you need to replace your cracked on with.
http://www.mymowerparts.com/partdetail/1125/15474.php
Once on the page, you can enter "primer bulb" in the quick search box and it will show all bulbs for all the chainsaw models available. About the 3rd section down will have the McCulloch bulbs listed.
Hope you find this Very Helpful and best regards!
Aug 15, 2009 | McCulloch Garden
Primer bulb not filling
Yes, I think the gas cap may be clogged. The gas cap must be able to breath, otherwise this vacuum will occur. Try starting your trimmer and when it starts to choke out, loosen the gas cap. It should get air back in the tank, then and keep running. If this works, clear the hole in the gas cap, or purchase a new one.
Jim
May 03, 2009 | McCulloch 26cc Gas Blower Mcb3208
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
158 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
