Question about Toshiba TDP-S8 Multimedia Projector
Toshiba TDP S8 projector shuts down suddenly
My Toshiba TDP S8 projector shuts down suddenly and the lamp indicator is blinking then off. After that it goes stand by then back on after 5-10 minutes
  • cliff24043 Feb 13, 2008
    I have the same symptoms with my projector. It has low lamp hours & is used occationally. Unit is ceiling mounted - no jarring, etc. I don't think it is the lamp... no hi-temp warning, maybe a bad thermal switch?
  • bullock_cd Jan 02, 2009
    My projector is ceiling mounted and the yellow light blinks on and off. When it does come on the picture is blurred then bright. Is the lamp going out?
    Problem Solver:
  • 7 Answers
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Posted on Apr 06, 2008
Most probably the lamp is dead already.
jimag2008
Posted on Jan 24, 2008
Lamp hours reset Toshiba TDP S9
Posted on Apr 28, 2009
Greetings! I own a xp2 Toshiba projector, and it has a blinking orange indicator under the word lamp on top of it. Projector was running perfectly when suddenly it turned off the light while giving a...
Sounds like you have the wrong bulb or your
unit is overheating, a dangerous issue.
Check for dirt clogged vent openings.
I suggest buy a new one for safety reasons.
Oct 13, 2017 | Toshiba TDP-S8 Multimedia Projector
My projector lamp turn on about 2 then turn off. light bulb haves
the power supply needs to be replaced. if you're good at soldering, there is a capacitor that dries up quickly on the ps board. i believe it's c2.
Nov 09, 2009 | Toshiba TDP-S8 Multimedia Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Toshiba Projector won't turn on!!!
I had the same. Try to press the "input" and "menue" buttons and plug in the power cable. No control light should be active after that. Press the "power" button and it should work.
Dec 19, 2008 | Toshiba TDP-S8 Multimedia Projector
Same problem as below.
I have the same projector, and had the SAME problem.
After unplugging and taking on a trip it didn't work...it just lit up for 2 secs, and then shut off....
LEAVE it plugged in for as long as it takes for the light to stop blinking, and then it should start up on its own, or if you press the on/standby buton.
Be patient, hope this works for you too!
Sep 01, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba Lamp Reset - How?
Not positive, but I would assume the same as my Toshiba.
With the on, input, and menu buttons held down, insert the power cable.
Hope this helps, NGK
Aug 14, 2008 | Toshiba TDP-S8 Multimedia Projector
Projecter not working
I have this same problem with no indication of what is wrong with the projector. I have checked the bulb and see no lines (veins) or bubbles on it.
Jul 20, 2008 | Toshiba TDP-S8 Multimedia Projector
Standby light for toshiba
probably power supply or ballast (starts the lamp)
either would be $600.00 or so to repair, probably costs more than the projector is worth.
Jul 15, 2008 | Toshiba TDP-S8 Multimedia Projector
Name
Hi j cwff
Ok this would be a faulty lamp if you can spot bubbles or vein like looking marks on it in either black or white.
I'm sure you'll solve this by just replacing the lamp and resetting the lamp timer.
May 26, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-S8 Multimedia Projector Logo
1,265 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
