Won't spin will not spin at the end of the cycle
  • 296 Answers
Hi, Most possible causes are:-
1.Make sure the lid is closed. There is a switch inside that completes the connection. Your washer may not spin or agitate if this connection is not completed. Make sure that the speed selector switch is not between speeds. Verify that the washer is not in a soak cycle. You can also reset the water level up or down to make sure that the water level control switch isn't stuck. If you hear a humming sound when the washer is full of water, you may have something stuck in the drain pump.
2.If one of these is not the problem, check the belt. The main drive motor has two distinct functions. The first function is to spin the basket; the second function is to reciprocate your agitator. Inside your washer's transmission is a crank type gear and connecting rods that are used to agitate the washer, with the spinning coming from the washer motor itself. This usually entails some sort of clutch mechanism. Some things to check if your washer is not agitating and/or spinning are:
3.If you notice weak or no agitation, the splines connecting the agitator to the drive shaft may be stripped and need to be replaced.
4.After a lot of use, belts can become worn or damaged. Replace any worn or damaged belts immediately. If you have a broken belt, replace it and check the pulley to make sure it's not seized.
5.Sometimes the drive pulley can wear out and it won't turn the drive belt. Look for wear marks, pits, or uneven spots. It's best to just replace it with a new pulley.
6.Many washers use a reversing motor. Sometimes it will continue to work in one direction even if it won't spin in the other direction. If your washer has a drive motor issue, you probably need to replace the motor with a new one.
7.The lid switch is a safety device that's there to protect you from sticking your hands into a spinning washer. If this switch goes bad, the washer will not work. You will have to replace it. It is inside the main housing for the washer, and located near the door frame.
8.The coupler connects the motor to the transmission. After lengthy use, this plastic and rubber coupler can wear out. If this happens, you need to replace it.
9.Transmission and clutch assemblies can cause agitator and spinning problems They are fairly complex.
Thanks! mannu_rakesh
Posted on Sep 08, 2009
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Nov 26, 2014 | Washing Machines
My Hotpoint wf000 1000 spin model won't spin. It goes through a full wash cycle, agitates fine, but just won't spin at the end of the wash. Any help appreciated.
Sorry if it may be too obvious, but have you checked the philtre? generally they stop spinning when it's stuffed... when you open it, make sure you have a mop and bucket handy, some water will come out!
Nov 06, 2012 | Washing Machines
My Defy Automaid DAW285 only works when you put in a small load of washing
It seems that the "start" winding of the motor is defective or the capacitor is defective
Peet
Nov 15, 2011 | Washing Machines
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
Won't spin out the water
If your problem is that it won't go into an accelerated spin cycle at the end, check the settings. Most washers just let water drain out the bottom when they have finished cleaning.
May 15, 2011 | Washing Machines
At the end of the cycle prior to spinning the washer sometimes doesn,t start to spin, it just makes sounds like it,s trying to spin but won,t catch. If I open and close the lid it begins it,s proper cycle....
The timer is not allowing a cycle stop for the neutral pack to drop. Replace the timer and you should be in good shape. The whistling sound is likely something in the pump.
Kelly
Mar 21, 2011 | Whirlpool Washing Machines
Washer will not spin The washer is a frigidaire front loader model LTF2140E53. will cycle through all settings, but will not spin. Cycle ends with clothes soaked.
I have thata probelm a lot too. I have read that the controls don't sense that the door fully shut. You might try slamming it shut, jiggling the door, poking in the hole where the latch goes. When mine won;t spin, slamming and jiggling works.
Jan 24, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
