Question about Frigidaire FRS23KR4AQ Side by Side Refrigerator
THE FOOD IS FREEZING IN THE NON FREEZER SIDE OF SIDE BY SIDE
The food is freezing on the non-freezer side and the water does not come out of the front. Have found water frozen in the water filter. I am not sure which of the models ... all I could find is the following model # : FRS23KR4A
    Sergeant:
    Champion:
  • 214 Answers
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Freezer freezing and refrigerator freezing
Search round the top/bottom/sides of fridge and freezer for a regulator switch. Usually a small serrated wheel numbered 1-5. It should be set at 2 or 3. Any more and you will freeze up.
Jul 12, 2012 | GALAXY Microsystems 25.4 cu. ft....
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
Food freezing in fridge compartment in my side by side
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | KitchenAid KSCS25FKSS Side by Side...
Ice and water not working, then freezing in refrigerator, leaking
If the water tank in the fresh food section is leaking then you will need to replace it. the freezing in the fresh food section is due to the damper door not closing when it should. at the top left of the fresh food side there is a door that controls how much cold air it gets from the Freezer side. This door on your GE is controled by a motorized door witch is controled by a controlboard witch is reading sensors in your freezer and freshfood section for tempretures.
In short your freezing problem could be any of these:
temp sensor, Motorized damper door or control board. I would check the Motorized damper door first.
Jan 07, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Refrigerator leaking water from freezer compartment, freezing along walls of freezer, but running water out under door
Sounds like the defrost water drain is plugged up. It could be a piece of food wrapper fell into it, or something. What make and model is it? Top freezer? Side by Side?
Dec 30, 2009 | Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fresh food side too warm
Refrigerator nguyen@ite.net 40 F or lower is the recommended refrigerator temperature to slow bacterial growth and maintain quality. Freezing occurs at 32 F; adjust refrigerator accordingly between 32 F and 40 F to prevent unwanted freezing, such as freezing milk.
http://lancaster.unl.edu/food/ciq-fridge-freezer-thermometer.shtml
Jun 09, 2009 | GE GSS25JFM Side by Side Refrigerator
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
Frigidaire FRS23KR4AQ Side by Side Refrigerator Logo
103 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
