Question about RCA Pearl TH1102 MP3 Player
Unit turns on but will not do anything or go to menu.
Unit was working fine. Shut it off for awhile and when I came back and turned it on it would not bootup, it just shows the PEARL logo and nothing else.
Repeatedly removed and reinserted battery while holding down the menu button until the unit rebooted. Don't know why.
Posted on Sep 09, 2009
I have an Optoma HD 8000 projector and while watching TV the lamp will turn off what can I do to repair the issue
if the lamp, lamp driver,power supply,Scaler Board and Formatter Board were good.
perhaps it is over temperature protection.
whether you checked with the air filter( dust filter) is clean or dirty?
Jul 02, 2014 | Optoma EP7155 DLP Projector
Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it
hi. the led tv turn off itseft aroun 5 minutes was complete shut off or another ?? need more data???
Jan 08, 2014 | Westinghouse LD-4655VX 46" LED TV...
When I turn on my 42" vizio all I get is the vizio screen no sound and the remote will not work to turn it off.after being unplugged for awhile (days) i tried it again and it worked fine until i shut
You will need to get a diagnosis done on the set. It could be a power supply issue or a main board issue. Your problem is between one of those two boards.
Apr 04, 2013 | Vizio VW42LF 42 in. LCD HDTV
My engine doesnt turn over
Before you start pulling the motor down, just check the ignition unit has not come loose and is hitting the flywheel
May 12, 2012 | Garden
My keurig b70 coffee maker says prime. sounds like the pump works for awhile then stops. prime lights up on the screen and doesnt let me do anything else why
Mine would brew the first cup fine, then the pump would run but would not draw water from the reservoir. I turn it off, turn it back on it would draw water for one cup then would not draw water again. I unplugged it waited 30 seconds and plugged it back in, assuming that would reset the electronics. It worked fine following the PDPU (power down, power up) procedure. Simply turning it off will NOT reset the processor, you MUST unplug the unit. Remember to wait 30 seconds or so prior to plugging the unit back in.
Nov 28, 2011 | Keurig Platinum B70 Coffee Maker
I have an RCA HD52W59 TV that will turn on and picture is fine for awhile, then it will fade to total black. Still has sound and does not power off. Nothing will show on screen, not even menu options....
Thats a deflection problem which is causing the CRTs to shut down during deflection loss. The deflection board will need replacement. You can get replacement deflection boards from www.tvrepairworld.com
Apr 23, 2011 | RCA HD52W59 HDTV Projection Television
Dell inspiron 2650 frozen on blue welcome page
try this...
turn on the laptop,,,
keep pressing F8
a menu screen will appear,, select SAFE MODE using the cursor keys and hit enter,,
once it boots in safe mode click no to use system restore..
follow the onscreen instructions to send it back to a date when it did work,,
it will shut it self down and restart in a propper manner..
if that fails,,
when u turn on the laptop it displays a menu,, it shows to press a certin key to enter system recovery,, press that key,,
follow the onscreen instructions to restor the laptop to factory condition..
Jun 03, 2010 | Dell Inspiron 2650 Notebook
My laptop is a hand-me-down from about 2004. it has been slow for awhile, but worked fine. today i went to open it and it shut down. it then turned back on and shows a blue screen that says "Your computer...
While the computer is booting up you should be able to hit F8 repeatedly and be offered the option to boot into safe mode. This will allow you to access your files.
Since the computer is already slow, I would back up these files to a thumb drive and just reformat using restore disks if you have any. If you don't let me know and we can explore further.
Sep 24, 2009 | Computers & Internet
Won't turn off or on, wont do anything, is lit up though
Might try a warm reset. Unscrew the plastic top of the stylis. and push it into the reset hole in the back of the unit, remone it from the reset hole, then turn unit back on.
Mar 15, 2009 | Garmin iQue 3600 GPS Receiver
VS-45607 Rear Projection Television
Resoldered connector DY on the yokes and check caps C411, 2200uf/35v and C412, 10uf/50v on main pc board.
Bill
May 04, 2008 | Mitsubishi VS-45607 45" Rear Projection...
RCA Pearl TH1102 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
