Question about Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher
Viking vud141 - timer does not end the cycle
Where can I buy the the timer for dishwasher without me costing more than a new dishwasher ?
thanks
behmoaras
mmikeb@attglobal.net
You can try this number 305-418-0010 they have everythin for viking product and very cheap
Posted on Feb 05, 2008
THERE ARE NO CLOGS ANYWHERE IN THIS DISHWASHER VUD141-SS. EVERY AREA HAS BEEN CHECKED FOR POSSIBLE FOR CLOGS. DISHES ARE CLEAN AND THE WATER CYCLES FINE. HOWEVER WHEN THE TIMER REACHES THE CYCLE WHERE THE...
yes the drain pump should start at this point so I would suspect a faulty drain pump,But try a reset first push and hold power button until lights reset then try a cycle if this fails to fix problem then I would suspect the drain pump.adrian,,,,,
Feb 11, 2015 | Viking Dishwashers
I have a Vikin Dishwasher Model DFUD042 and the arms are not circulating water. When we start a cycle it drains previous water then fills it up after that it runs thought its regular cycle but the arms are...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
42gda
Apr 21, 2010 | Viking 24 in. Professional Series VUD141...
How do I find the door lock and a door seal (bottom of door) for my Viking VUD141 ?
Don't know about the lock, but the bottom seal for the VUD141 is part # PD100091 (just had mine replaced).
Mar 20, 2010 | Viking 24 in. Professional Series VUD141...
Pump will not stop pumping
It may be in "delime mode" check the manual.
If not the timer is likely at fault.
Dec 24, 2009 | Viking 24 in. Professional Series VUD141...
Viking VUD141 advances through the cycles but won't drain water
The unit should be installed with a high loop in the drain line at the rear of the unit. If this is not in place it can cause the drain water to run back into the unit. If there is a partial blockage it could result in incomplete drain. Try disconnecting the drain line below the sink and run the unit to drain into a bucket see how it drains. would be a sign as to how free your drain line is.
It could also have defective drain pump
Jan 10, 2009 | Viking 24 in. Professional Series VUD141...
Viking Dishwasher Timer Dial not advancing
The timer has given it up.  The motor has probably stopped working or the gears are jammed.  You'll need to obtain and change the timer.  Generally, there are face mounted screws that may or may not be behind some covers.  Remove them to get to the panel that holds the timer.
Nov 20, 2008 | Viking 24 in. Professional Series VUD141...
Left Knob Settings
On our model VUD141, the knob has a mark and the cycles are printed on the front panel. It is labeled as follows (starting from straight up and going clockwise):
OFF - Heated Dry - No Heat Dry Sani Cycles 165 deg F - Power Heat Selection - No Heat Dry - Heated Dry
Jan 05, 2008 | Viking 24 in. Professional Series VUD141...
TIMER DOES NOT ADVANCE
At the point where the wiring comes from the bottom of the tank and rises up the door is prone to burning. Before doing the following remove power from your dishwasher. By removing the kickplate at the front and inspacting the bundle of wires you may note that some of the wires are lumpy or burned. These wires need to be repaired. Failing that there is a cycling thermostat mounted to the bottom of the tank above the water valve. These cycling thermos will prevent the timer from advancing there should be a wiring diagram inside of the door that will help your efforts.
Feb 01, 2007 | Viking 24 in. Professional Series VUD141...
Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher Logo
263 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
