Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Need Brother Contol Center3 put back on my computer
Hi..I have a MFC-465CN & my husband lost everything on us a months ago. The Control Center3 does not come up any longer. Everything woeks except the scanner...Please Help..I've been trying everything since June.....
MY COMPUTER HAD A VIRUS AND THE GUY DELETE THE INFORMATION AND REINSTALL EVERYTHING AGAIN, BUT I LOST THE DISC FOR INSTALL MY MFC 465MC, CAN YOU HELP ME?
PLease check and confirm the model number, (The closest match available is MFC 465CN)
You can download the installation driver and software for Brother MFC 465CN from manufacturer's website by clicking this link
On the page which opens:
  • Select the operating system of your computer (Windows Xp/ Vista..) from the drop-down list
  • Select the Language (English) and click the Search button
  • Download and install the drivers and software from the next page which opens.
Hope this solves your problem. Thanks for using FixYa.
Apr 09, 2011 | Brother MFC-465CN InkJet Printer
I lost my installer,how can i install my Brother MFC-465CN InkJet Printer back?thanks..
you may download from " http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/colormfc/mfc465cn_all.html?reg=us&c=us&lang=en&prod=mfc465cn_all "
Aug 21, 2010 | Brother MFC-465CN InkJet Printer
Brother MFC-465CN printer. Need a fix for error 46.
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Jul 09, 2010 | Brother MFC-465CN InkJet Printer
How to install brother printer mfc-465cn
Here is a link to Brother to download the software / drivers for the MFC-465cn. You will need to select which Operating System that your computer is running in Step 1:Select OS....
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc465cn_all
Mar 24, 2010 | Brother MFC-465CN InkJet Printer
Brother mfc-465cn opening raster file failed
Try downoading the drivers from the apple web site. You would need the brother 1.1 drivers download.
Remove printer then added it again
Jan 02, 2010 | Brother MFC-465CN InkJet Printer
Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 18, 2009 | Brother MFC-465CN InkJet Printer
Brother mfc-465CN on LAN but will not print. Has done in the past but suddenly stopped. On printer control panel it showed as being unavailable. Other PC's on network print to it ok and the problem PC can...
can you ping your printer from that computer? if not then can you ping other computers on your network? If not then there is something wrong with your computer network on that computer.
Nov 23, 2009 | Brother MFC-465CN InkJet Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
95 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
