The ice maker still works fine, but every once in a while, when not at the refrigerator, we will here a loud click. It sounds like the click it makes after it stops dropping ice. There is some calcium build up around the water spout and I would guess that calcium build up around a switch/sensor is causing this problem, but don't know how to get inside to clean it out. Can you tell me how to take it apart to clean the inside parts? Perhaps a diagram?
Thanks
The ice
maker not working: ---
Its the problem of water inlet valve. It's a
dual valve. This valve has two tubes in it. One for water dispenser and one
for ice maker chamber. The one side of valve is working, but other side of the
valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the
problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
dispenser does not turn screw for ice ejection. like no power to switch. ice maker works fine otherwise.
