Question about Porter Cable Tools & Hardware - Others
I have a Porter Cable Speed Bloc sander and I was wondering how to change the springs for the 1/4 sheet hold down without going CRAZY.
I was going crazy trying to figure this out also, the thing that I did that worked pretty well involved grabbing the "loose" ends of the springs with two pairs of small vise grips and holding the spring in exactly the right position to either remove or install the pin that goes across and holds the clamp on. It's really tricky and although I did it myself it would be helpful to have another person there to hold things, it's a bit surgical-like. You will need two pairs of small or needle-nose vise grips, don't even attempt to do it without those, you can't hold the tiny spring wire well enough with regular pliers.
Posted on Aug 24, 2012
I'd tell you but I'd have to charge $12.99. for the info. I went to a free blog instead.
Posted on Sep 09, 2009
Installing brushes in porter cable 7336
Go on line to porter cable customer service ask for a blow out of the motor of your 7336 assembly 6 inch variable speed sander they will have the parts blow up showing each part with a line going into each area where the parts fit together Good luck
Aug 26, 2012 | Porter Cable 7336 6 Inch Variable Speed...
I inherited this sander (Porter-Cable model 330) and the owners manual did not come with it. I am stumped as to how and get the side levers to lift so that i can change the sandpaper (non-stick paper)....
there is a wrench supplied with the tool that you need to insert in the slot on the clamp and push the wrench towards the tool to open the clamp. Now if you follow closely I can direct you to a manual and parts list. Go to "dewaltservicenet.com" and scroll down to the bottom and you will find a porter cable link, click on that and then when you get to the next page click on tools. Scroll down till you find sanders and click on that. Next find finishing sanders and you will find your model sander click on the description and it will again redirect you to another page where you can find the manual. The whole manual is 44 pages long but that includes other languages. The page that you specifically need is page 10. If you have a problem let me know and I will try and help. This is the first time that I have had to take this route to find a manual on their site.
Jul 13, 2011 | Porter Cable Cable 0330 Speed - Bloc...
Porter cable sander lost power.
Similar problem with my 7500 2x18" belt sander. Replaced the brushes today (didn;t look bad{ had sander 3 months to sand pistol grips. Sparks were flying from motor so replaced the brushes. Skil runs very slugis like its booging down, I think the only other possible solution is new bearings for me and perhaps you..
Apr 08, 2010 | Porter Cable 505 Factory Reconditioned...
The foam part that forms the base onto which you can attach self adhesive sand paper to has fallen apart and I need to purchase the replacement foam and or aluminum backing plate
I think I found what you are looking for ... when you get there click on the picture of the type you have and follow through to check out.
Hope this helps,
RSMITH972278
P.S. PLEASE DON'T FORGET TO RATE ME !
Oct 14, 2009 | Porter Cable Cable 0330 Speed - Bloc...
Extreme Vibration in my Porter Cable (Rockwell) 330 Sander
I also have had this problem and I found that if I hold the unit tightly and squeeze the plastic housing the RPM's will stabilize as the unit warms up. Best fix is to replace the rubber isolators that prevent vibrations from the motor from reaching the plastic housing. The isolators have become hard through age or very cold temperatures.
I read somewhere that keeping the sander stored in a warm room can also help because when the rubber is very cold it becomes hard.
Oct 07, 2009 | Porter Cable Porter-Cable Speed-Bloc...
How do you replace bearings on a porter cable 505 sander?
First I would go to Dewaltservicenet.com and in the middle of the site towards the bottom type in your model number. I found breakdown on page 8 unless it comes up faster. You will need a bearing puller or something similar because they are pressed on. It is really not that hard with the proper tools. Let me know and if I have answered your question would you please rate this response accordingly and Thank you.
Sep 08, 2009 | Porter Cable Porter-Cable Half-Sheet...
Slows down and looses power intermettently
you need new brushes or clean out the holes they go in so they move freely
Aug 08, 2009 | Porter Cable Porter-Cable Variable Speed...
Excess vibration
Remove the 4 sander plate screws being carefull not to strip them. Look at the plastic ******** extentions attached/flooting to the houseing and look for broken or bent arms on them ,replace with new ones, this should solve your problem.
Mar 19, 2009 | Porter Cable Cable 0330 Speed - Bloc...
Tools & Hardware - Others Logo
124 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim London
Jim London
Ed Mac
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
