Question about Vehicle Parts & Accessories
Speaker problem with XTR-695
I have a 1 month old XTR-695 when the voice come on the speaker it sounds like there is a short you cannot understand what it is saying. help
    Sergeant:
  • 347 Answers
You can contact whistler for thier return policy
Posted on Jan 07, 2010
Whistler xtr 690 voice need to be fix
If your unit is under 3 years old, contact Whistler at Info@whistlergroup.com for info on how to have warranty service performed. If its over 3 years old then you can call them at 800-531-0004 to order a speaker. This assumes that you tried a factory reset and that the auto quiet and City modes are off which basically leaves only the speaker as the possible problem.
Sep 28, 2011 | XTR-690 Radar Detector
Stereo cutting off when volume is over 29
Twenty nine sounds pretty loud to me. A shorted voice coil in any one of your speakers will drop its resistance value so if the amplifier thinks its feeding a short circuit, will "protect" itself by shutting off. Check wiring carefully and each speaker at a little lower volume for sounds of distortion ie: shorted voice coils...
Jun 27, 2009 | Kenwood Marine Receivr/Speaker CD/MP3/WMA...
Earlywarning ew3010de voice is messed up can't understand what the thing is saying
The speaker's voice coil likely has overheated, and now it is rubbing on the insides of the speaker magnet. This causes very garbled sound. All Sunkyong Early Warning radar detectors provide horrible radar detection performance. You should seriously consider getting a much better radar detector.
Apr 18, 2009 | EW-3010 Radar Detector
Does not sound alarm till its to late
The lower end Whistler radar detector models do not have particularly good performance against all radar gun frequencies. Whistler's XTR-690, Pro78 and XTR-695 on the other hand do perform very well against all police radar guns. Its basically a matter of you get what you pay for.
Mar 18, 2009 | DE-1793 Radar Detector
Dell no sound
I also have Dell W2600 TV and have sound problems
Dec 14, 2008 | Dell W2600 26 in. LCD Television
Celestion g12l
I think that one reason for a speaker to rub is due to over heating of the voice coil. This happens when power is applied to the speaker that is greater than the speaker is capable of handling. A second cause could be that the suspension and or cone is damaged or degraded causing the coil to be tilted or off center. In either case nothing short of rebuilding the speaker can be done to repair the speaker. Rebuilding would involve removing the cone and voice coil and replacing with new items. If you were talented you might be able to repair the existing cone or voice coil but the results could be iffy.
Sep 08, 2008 | Celestion 20i Speaker
New speaker
call 800-531-0004 to order a speaker for your 1660. For the XTR-690 its best to return it for service under warranty.
Aug 19, 2008 | Vehicle Parts & Accessories
Sound problem
You have a shorted speaker or a speaker with a bad voice coil. This has been confirmed by the fact that the audio amplifier is shutting down (protection) but the unit stays powered on. The speakers will play for a few seconds or maybe even longer at lower volume, but any length or time or an increase in volume will immediateley shut off sound. This is due to the fact that a shorted speaker wire/connection will ground out or short to one another. If you have checked all connections behind the radio AND at the speakers and found no problems, then it is a voice coil on the speaker. A shorted voice coil will work until the speaker cone moves causing the short or until enough power passes through the voice coil's short to turn off the radio.
Solution:
1. You can use a voltmeter set to check continuity to test for a speaker short. Disconnect all speakers from the radio and connect one side of your meter to ground and the other to the speaker lead. An audible "beep" will confirm a short.
2. The other method would be to disconnect all speakers and re-connect them one by one until the radio's sound output shuts off again. This will be your shorted speaker.
I hope this information was helpful.
Apr 07, 2008 | Pioneer DEH-1800 CD Player
Whistler XTR 560- won't turn on
As you only had it one month return it under warrenty
Jun 23, 2007 | XTR 560 Radar Detector
Vehicle Parts & Accessories Logo
199 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
