Question about Panasonic KX-P1695 Matrix Printer
Won't print all of the letters
I have put a new ribbon in it but it will only print part of the words in black and the rest are very lightly printed. What could be wrong with it. Need help as this a bookwork printer I need.
  • 97 Answers
The ball needs cleaning with a putty to get the debris from all the other apges that it has printed out of the letter on the ball
Posted on Mar 21, 2008
Won't print large font in solid black. Only prints outline of letters in black
Try resetting word to factory settings to clear all the settings, Then make a new document and type whatever you want with the font size you require, save then print, see what happens.
Mar 10, 2015 | Office Equipment & Supplies
Why does my Canon MP49D calculator print light?
Could it be you are using old ribbons? Are you using the correct ribbons?
did you put in the ribbon correct and is the ribbon transported, while it is printing, or is it stuck in the calculator. Just some questions to check out.
May 06, 2014 | Canon Office Equipment & Supplies
My Swintec 7040 when I type a letter or word only write a half of the letter or the word and when I try to erase a letter or word the typewriter erase this but the erase ribbon stay in the same position...
There are a few possibilities. If only the tops are printing Press down on the platen to be sure it is fully seated in the side frame. The T/W may be in the overstrike ribbon mode Code period, comma or slash will get you out of that mode.
DickyO
Oct 11, 2011 | Swintec 7040 Typewriter
DOESN'T SEEM TO HIT HARD ENOUGH ON RIBBON TO MAKE COMPLETE LETTER ON PAPER, IT'S LIKE YOU ARE USING A OLD RIBBON THAT HAS ALREADY BEEN TYPED ON ALSO AFTER A FEW WORDS IT STARTS PRINTING DIBBER. WHEN I...
could be a defective ribbon, try new one if it looks like the letters are almost typing on top of each other on the ribbon. it could be a problem with the ribbon drive of the printhammer. if a new ribbon doesn't help, get professional help.
Feb 17, 2011 | Brother GX-6750 Typewriter
I put in a new wheel and new ribbon with correction tape; was working fine but all of a sudden, it won't print correctly. It prints on the very top edge of the ribbon and the letters do not print...
On the older WW's there is a large black plastic gear on the R. side of the printer they do get tooth for tooth. try wiggling it to free it up, with the power off it should move easily.
DickyO
Oct 13, 2010 | IBM Wheelwriter 6 Typewriter
My printer has stopped printing the letters onto the dvd properly
1. Remove lid/top
2. Move blue lever left or right to unlock ribbon roll
3. Loosen ribbon or tighten as needed -
NOTES: If ribbon roll is too tight it will show wrinkles; it should look smooth if positioned correctly; if too tight it will not print portions of some letters; keep re-positioning if this does not work after first try.
4. Use flat-head screw driver to adjust front uptake (used) ribbon-roll as needed to make it smooth too. Lift out & re-position, if you need to.
THIS WORKED FOR ME but I had to re-do my re-positioning of both rolls several times before it began printing 100% of letters again. 4bb240d8-5e9d-4611-9ca4-33b5883e40b9.jpg 5a5b4381-7ee8-480f-943e-041aa738011d.jpg c86d59ae-1b7e-4755-b895-08007064e847.jpg Journal Kentucky Lexington Monitor www jklm us
May 20, 2010 | Rimage Perfect Image Prism Thermal Printer
My printer only prints pictures, no text.
Sounds like your black pigment (PGBK-5) cartridge has clogged up the printhead or similar.
You could try running a single Deep clean on the that colour alone (use Right click printer > printing preferences > maintenance tab > Deep Cleaning)
If that doesn't work you will probably need to either:
- clean the printhead (see this thread)
or
- replace the printhead/cartridge
Hope that helps.
Mar 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
TYPING II IN PLACE OF LETTERS
the mark you are seeing is the print hammer hitting the paper. remove the ribbon. corr. tape & print wheel. turn on the typewriter. close cover let it home it's self. open cover put in print wheel. close cover let it nome. put in ribbon close cover. try typing if marks are still ther. you will need a new print wheel. if working then put in corr. tape or if you are better at spelling then me you will not need it
Jan 21, 2009 | Smith Corona Wordsmith 200 Typewriter
KEY STRIKING PRESSURE
Try taking the ribbon out and looking at it see if there is one spot for each character on the ribbon or if they are overlapping.If they are over lapping then either you have a problem with the ribbon drive assembly on the machine or it is set for a multi-strike ribbon.
Nov 13, 2007 | Lexmark Wheelwriter 15 Series II...
59 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
