Question about Kenmore 24032\24036 Top Load Washer
Machine washes but will not spin and drain to go through the rinse cycle??
  • 5,911 Answers
Check your lid switch.
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
A new lid switch (if needed) can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all them for the best price.
If you have questions, or need additional assistance, please let me know. Please post back with a complete model number (located on a nameplate around the wash tub opening) with your questions, so that I may be able to provide you with better assistance. I hope this is helpful.
NOTE: You do not need to bail or empty the wash tub to complete this repair.
Posted on Sep 08, 2009
Testimonial: "This information was very helpful. I though it might be the lid switch. Thanks!"
Washing machine wont drain,rinse,spin,water wont drain out start a cycle but seems not to rinse,spin,drain
Could be a failed lid switch. This is a safety switch that shuts the machine off during cycles.
May 19, 2016 | Washing Machines
Washer won't spin
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
I have been getting the Sd code and then F21 code during regular wash. I followed directions cleaning out white filter on bottom of machine and it did not help. So I followed directions for resetting the...
need to replace the part but dont try it if you dont have idea how to do.
call the technician for your safety and not to waste money.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Mar 18, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
MACHINE DOESN'T CYCLE OUT OF RINSE
Does it spin if you move the timer manually? ist it being used on a delicate cycle@? if so it will stop in the last rinse water
Jul 10, 2007 | Ariston Technologies AWD 121
Freezer before Rinse
you hav'nt said if it drains. the problem just may be that you have plumbed drain hose onto a spigot on the sink drain and spigot is blanked off
Apr 24, 2007 | Creda W120VW Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
