Question about IBM ThinkPad R50e Notebook
R50e laptop I am not able to use the power adapter for recharging or for a power supply, is it my power port? To confirm I have used the adapter on another similar laptop and no problem with this, I have also switched battery with another similar laptop and my laptop works. How do I fix this?
  • 317 Answers
It's probably your power jack inside your laptop. It's attached to your motherboard, it's not making a connection with the cable when you plug it in.
Check out this link
Or you might have to call a local repair shop.
Posted on Dec 09, 2007
Why won't my dell e-port ii replicator charge my latitude e5540?
1. battery is old and can't recharge.
2. Power supply are different, usually two type supported. 3.34/4.62 sometimes it permit to start but don't recharge if battery want exact Voltage.
3. You are using Power Supply for Laptop to E-port, that need 6.7A, so at same it can't recharge correctly your laptop
Jun 05, 2014 | Dell Precision Latitude E-Port Plus Port...
Since yesterday I noticed my battery isnt automatically recharging when its plugged in. Why is that? The battery indicator is blinking (green). Im using asus a42j.
Welcome to FixYa!
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jul 17, 2011 | ASUS Computers & Internet
The usb ports and the ethernet port do not work - suddenly happened - R50E
restore your system to a previous date and time using the system restore wizard. what operating system are you using?
Jun 13, 2011 | IBM ThinkPad R50e Notebook
Couldn't setup the wireless on ibm thinkpad r50e as well doesn't appear to be available at device manager as well network controller on device manager is not setup. could i know from where i could get the...
It appears not all R50e laptops come with wireless interface built in. This means if your model is one of those then you will have to buy a wirelss adapter and put it in the USB port or use a PCI wireless adapter if it has a mini PCI slot.
Check this site.
You will need to confirm what model type your laptop is and download the specific user manual from this site to see if there is a wireless connection. You could also refer to this service manual if it helps in identifying the actual wireless interface for your model.
Feb 13, 2011 | IBM ThinkPad R50e Notebook
How do you recharge a MA933A-1PT without buying a baterry
MP3 players have a rechargeable battery. It can be recharged by plugging it into a USB port os a powered up computer. The other way is to use an mains adapter USB power supply/charger.
Feb 07, 2010 | Nextar MA933A MP3 Player
Power cord attachment into the back of computer seems worn, it wants to run off battery instead of recharging through power supply
Either Have A Failing AC Adapter, Or A Failing DC Jack
you can test the AC Adapter using a multimeter (available at any home improvement center for $6)..
The DC Jack Would Need To Physically Be Checked To See If It's Faulty... which would intail removal of all parts down to the motherboard and visually inspect the DC Jack (the port where the Charger Cord Plugs into)
Remove The Battery... Plug AC Adapter Into Laptop.. Attempt To Power On....
Nov 15, 2009 | Acer Aspire 5100 Notebook
How to take off the motherboard r50e?
u need to take out the board, then use a soldering iron (very powerful one) but if you dont know how to remove a board how the hell will you replace or fix the usb port??
Jan 18, 2009 | IBM ThinkPad R50e Notebook
Not receiving power from ac adapter
Mine had a bad wire in the power supply.
Aug 27, 2008 | Toshiba Satellite A135-S4527 Notebook
R50e PC Notebook Problem
And once you get the power socket (pin) repaired, get a Cable Retention Device like the video shows. . .
Dec 09, 2007 | IBM ThinkPad R50e Notebook
Power port failure
the power box may have when bad on you, if you have tried to use it with some thing other then the laptop it will blow and you would need a new one, look on ebay, it should have the numbers on it.
Dec 03, 2007 | Computers & Internet
IBM ThinkPad R50e Notebook Logo
44 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
