Question about Refrigerators
Leaking whirlpool fridge freezer ARG752WBM37 from freezer into fridge
  • Mike Smith
    Mike Smith May 11, 2010
    I am sorry , but the problem you refer to , did not pass the required information into your request such as correct model number and brand . If you would care to elaborate and reply with that information , to this post , then Fixya experts will endevour to help you further.
  • 93 Answers
That water is coming from you defrost cycle. Your defrost drain is plugged up with either ice, or possibly food, trash etc. Remove the back wall in the freezer....it is only a few screws. If you have an icemaker pull that out too, should be 3 screws usually. Pull that back wall and in the bottom beneath the coil you will probably see ice, or possibly a pool of water. Defrost that ice or chip it out with a screwdriver. Be carefull because the little drain pan in there is lightweight. You might want to use a hair dryer for this but it takes a little while. I usually just put hot water on it, but put a big bowl on the top shelf of the refrig to catch the water. After you melt it find the drain hole and flush it out. I usually run a peice of wire in it to unclog it. after you unclog it pour a cup of water down it to flush it out.
Posted on Sep 13, 2009
Freezer not working but fridge works
It uses the same compressor for both. One of two things, the opening that is allowing cold air in the freezer , is closed or the freon is leaking out and it will be soon before the fridge is not working.
Feb 21, 2013 | Whirlpool Freezers
Freezer leaking water into fridge
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 03, 2011 | Whirlpool Refrigerators
Water is leaking around the area of the light in my Whirlpool WRID41T fridge. The fridge is still cold but everything is totally wet. What can I do?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Jan 27, 2011 | Whirlpool Refrigerators
Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
Aug 24, 2009 | Whirlpool Freezers
Smelly Ice and water leaking into top shelf
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Leaking freezer into fridge
Hi, What has happened is that the drain hole in the freezer has frozen up and the defrost water is dripping into the fresh food area.
Remove the floor panel and the rear fan cover in the freezer and you see the ice that is blocking the drain.
Be carefull when removing the ice. DO NOT use a sharp object. The best way is to use a hair dryer.
Once you locate the drain hole, you will need to melt the ice down in the drain hole too. For this, you can use the hair dryer or poor a few glasses of hot water (sopping up the water between each glass).
What you will need to do after the drain is open is to put an after market drain heat transfer kit on to prevent this from reaccuring.
Please let me know if this is the case and I can get you the right part# or even send you the part.
Thakns
Vic
May 14, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Refrigerator leaking water
Try cleaning out the hose (on the exterior rear). This is the drain from the condenser to the evaporator pan.
May 12, 2009 | Whirlpool 18.8 cu. ft. Top Freezer...
Leaking Whirlpool fridge
Thanks for the question When this happens if the evaporator is all frosted up you have a derost problem could be your timer or your defrost thermostat which is located on the coils of the evaporator you can check this with a volt meter these meters are cheap you dont need a very expensive for ahout 20 dollars or the defrost timer one of the two is your problem thanks for the question The appliancedoc
Sep 11, 2008 | Whirlpool ET8WTKXK Top Freezer...
Refrigerators Logo
111 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
